Newbie Question igc files
Old June 8th 19, 08:21 PM posted to rec.aviation.soaring
Joel Flamenbaum[_2_]
Default Newbie Question igc files
Best program to open igc files?
Thanks in advance
Old June 8th 19, 08:51 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Thanks in advance
They're text files, so any text editor - Notepad in Windows, TextEdit for Mac will open it and display it as text.
If you want to see the file displayed graphically, there are free options. One that works online is https://igcviewer.bgaladder.net/ . Browse to the file, then open it. You get a view of the glider track, and a barogram.
Here's a list of analysis programs for IGC files:
http://www.ukiws.demon.co.uk/GFAC/do...%20 files.pdf
Old June 8th 19, 09:58 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Depends what you want to do with the file.
- To look at it as raw data, use any text editor (gedit if you run Linux,
Wordpad if you run Windows).
- To see flight statistics, etc, try GPLIGC, which runs under Linux or
Windows but is written in Perl, so you have to install Perl to use it.
Get it from http://pc12-c714.uibk.ac.at/GPLIGC/GPLIGC.php
It can also convert the log into an IGC file, but ignores any
turnpoints defined in the log.
- To display your flight using Google Earth, you need to convert the .igc
file into a .kml file. There are online converters:
- http://www.gpsvisualizer.com/map_input?form=googleearth
can save the converted file or start Google Earth to display it.
It shows turnpoints defined in the IGC log.
- Use this converter: http://cunimb.net/igc2kml.php
Save the .KML file and then open it with Google Earth.
Or you can buy a copy of SeeYou from Naviter, https://www.naviter.com/
Martin | martin at
Gregorie | gregorie dot org
Old June 8th 19, 10:14 PM posted to rec.aviation.soaring
Get it from http://pc12-c714.uibk.ac.at/GPLIGC/GPLIGC.php It can also
convert the log into an IGC file, but ignores any turnpoints defined
in the log.
For "convert the log into an IGC file" read "convert the log into a KML
file".
Martin | martin at
Old June 9th 19, 12:40 AM posted to rec.aviation.soaring
5Z
Another really good online viewer is https://www.soaringlab.eu
Will do a 3D replay using Google Earth
5Z
Old June 9th 19, 12:50 AM posted to rec.aviation.soaring
I typically just upload the file to cross country.aero. You can see the map and bariogram of your flight plus go through the igc file point by point. Helpful when trying to figure the min and max altitudes for the altitude leg of a badge.
Old July 4th 19, 05:51 PM posted to rec.aviation.soaring
On Saturday, June 8, 2019 at 6:50:35 PM UTC-5, wrote:
I typically just upload the file to cross country.aero. You can see the map and bariogram of your flight plus go through the igc file point by point.. Helpful when trying to figure the min and max altitudes for the altitude leg of a badge.
As you probably know but it might be worth reminding, there's quite a good deal of data available to you when you upload your flight (within 48 hours) on OLC (www.onlinecontest.org) and it's even free. Also, www.glideport.aero is a good source of free flight analysis.
If you want to do any kind of detailed analysis, SeeYou is the only serious tool. It comes with Oudie flight computers or can be bought via a permanent license (~$170) or through an annual subscription for ~$60/year.
Hope this helps.
Old July 5th 19, 05:25 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Thanks in advance
You might check out Soaringlab. https://www.soaringlab.eu/
Old July 5th 19, 07:20 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
Thanks in advance
Newbie S-NAV question dbrunone Soaring 14 April 14th 12 01:17 PM
Newbie VOR question Bruce W.1 Piloting 15 April 7th 05 05:15 PM
newbie question 2 Billy Who? Piloting 9 December 23rd 04 05:58 AM
A question only a newbie would ask Peter Duniho Piloting 68 August 18th 04 11:54 PM
Newbie question Bill Gribble Soaring 6 November 6th 03 07:57 PM
