de Havilland DH 108
Old October 24th 18, 04:16 PM posted to alt.binaries.pictures.aviation
Miloch
Default de Havilland DH 108
https://en.wikipedia.org/wiki/De_Havilland_DH_108
The de Havilland DH 108 "Swallow" was a British experimental aircraft designed
by John Carver Meadows Frost in October 1945. The DH 108 featured a tailless,
swept wing with a single vertical stabilizer, similar to the layout of the
wartime German Messerschmitt Me 163 Komet rocket-powered point-defence
interceptor. Initially designed to evaluate swept wing handling characteristics
at low and high subsonic speeds for the proposed early tailless design of the
Comet airliner, three examples of the DH 108 were built to Air Ministry
specifications E.1/45 and E.11/45. With the adoption of a conventional tail for
the Comet, the aircraft were used instead to investigate swept wing handling up
to supersonic speeds. All three prototypes were lost in fatal crashes.
Employing the main fuselage section and engine of the de Havilland Vampire mated
to a longer fuselage with a single tailfin and swept wings, the de Havilland DH
108 was proposed in 1944 as a test "mule" for the DH 106 Comet which had
initially been considered a tailless, swept-wing concept. Despite the Comet
design taking on more conventional features, the value of testing the unique
configuration to provide basic data for the DH.110 spurred de Havilland to
continue development of the DH 108. Selecting two airframes from the English
Electric Vampire F 1 production line, the new aircraft had unmistakable
similarities to its fighter origins, especially in the original forward fuselage
which retained the nose, cockpit and other components of the Vampire. The
Ministry of Supply named the DH 108 the "Swallow", a name that was never
officially adopted by the company.
The new metal wing incorporating a 43° sweepback was approximately 15% greater
in area than the standard Vampire wing. Control was based on the conventional
rudder in combination with elevons that were part elevator and ailerons, fitted
outboard of the split trailing edge flaps. Although the Vampire fuselage was
retained, as development continued, a revised nose and streamlined, reinforced
canopy were incorporated.
Role
experimental
Manufacturer
de Havilland
Designer
John Frost
First flight
15 May 1946
Introduction
Experimental programme only
Status
Cancelled
Primary user
Royal Aircraft Establishment
Produced
1946–1947
Number built
3
The first DH 108 prototype, serial number TG283, utilising the Vampire fuselage
and a 43° swept wing, flew on 15 May 1946 at RAF Woodbridge. Designed to
investigate low-speed handling, it was capable of only 280 mph (450 km/h). The
de Havilland Chief Test Pilot Geoffrey de Havilland Jr., son of de Havilland
company owner-designer Geoffrey de Havilland, gave a display flight in the DH
108 during the 1946 Society of British Aircraft Constructors (SBAC) airshow at
Radlett. In later low-speed testing designed to clear the rear fuselage at high
angles of attack, the first prototype was fitted with longer Sea Vampire landing
gear.
The second, high-speed prototype, TG306, with a 45° swept wing incorporating
automatic leading-edge Handley Page slats and powered by a de Havilland Goblin 3
turbojet, flew soon after in June 1946. Modifications to the design included a
more streamlined, longer nose and a smaller canopy (framed by a strengthened
metal fairing) facilitated by lowering the pilot's seat. While being used to
evaluate handling characteristics at high speed, on 27 September 1946 TG306
suffered a catastrophic structural failure that occurred in a dive from 10,000
ft (3,050 m) at Mach 0.9 and crashed in the Thames Estuary. The pilot, Geoffrey
de Havilland Jr., was killed in the accident. Early wind tunnel testing had
pointed to potentially dangerous flight behaviours, but pitch oscillation at
high speed had been unexpected. The subsequent accident investigation centred on
a structural failure that occurred as air built up at Mach 0.9, pitching the
aircraft into a shock stall that placed tremendous loads on the fuselage and
wings. The main spar cracked at the roots causing the wings to immediately fold
backwards
Finally, on 1 May 1950, during low-speed sideslip and stall tests, the first
prototype, TG283, was lost in a crash at Hartley Wintney killing the pilot, Sqn
Ldr George E.C. Genders AFC DFM. After abandoning the aircraft at low altitude
in an inverted spin, his parachute failed to open in time. In all, 480 flights
had been made by the three Swallows.
The DH108 established a number of "firsts" for a British aircraft: it was the
first British swept-winged jet aircraft and the first British tailless jet
aircraft.
Specifications (DH 108 VW120: third prototype)
General characteristics
Length: 29 ft 9.5 in (9.081 m)
Wingspan: 39 ft (12 m)
Wing area: 327.86 sq ft (30.459 m2)
Empty weight: 8,940 lb (4,055 kg)
Powerplant: 1 × de Havilland Goblin 4 centrifugal compressor jet engine, 3,738
lbf (16.63 kN) thrust
Performance
Maximum speed: 677 mph (1,090 km/h; 588 kn)
Range: 730 mi (634 nmi; 1,175 km)
Service ceiling: 35,425 ft (10,798 m)
Wing loading: 27 lb/sq ft (130 kg/m2)
Thrust/weight: 0.42
De Havilland DH112 Venom pics 3 [4/7] - Swedish Air Force de Havilland Vampires NOT Venoms for comparison.jpg (1/1) Miloch Aviation Photos 0 July 23rd 18 02:06 PM
de Havilland DH.66 Hercules pics 2 [4/7] - Imperial Airways De Havilland at Croydon Airport.jpg Lurker[_4_] Aviation Photos 0 July 16th 18 03:01 AM
de Havilland DH.103 Hornet pics [8/9] - Three de Havilland Sea Hornets F-20 of 801 squadron ranged on deck with engines running ready for take-off.jpg (1/1) Miloch Aviation Photos 0 November 30th 17 03:36 PM
de Havilland DH.103 Hornet pics [7/9] - Three de Havilland Sea Hornets F-20 of 801 Squadron in the upper hanger..jpg (1/1) Miloch Aviation Photos 0 November 30th 17 03:36 PM
de Havilland D.H.86 Express pics 1 [08/12] - De Havilland 86A. Miniature stabilising fins 1840-6.jpg (1/1) Miloch Aviation Photos 0 September 24th 17 03:29 PM
