Problem With Powerflarm Firmware Update?
Old June 10th 19, 04:59 PM posted to rec.aviation.soaring
Dan Marotta
Default Problem With Powerflarm Firmware Update?
Yesterday I updated my PF portable from version 6.60 to 6.67 and went
out for a short flight.Â* I found that Flarm targets were no longer
displayed on my ClearNav II display.Â* It still displayed ADS-B and PCAS
targets but no Flarm targets.Â* The PF portable still showed Flarm
targets.Â* Any ideas?
Dan, 5J
Old June 10th 19, 05:08 PM posted to rec.aviation.soaring
Tango Eight
Dan, 5J
6.67 works fine for me. Did you have a flarmcfg file on the USB? If you did, it got loaded... start there.
best,
Evan
Old June 10th 19, 09:33 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, I'll check.Â* But what difference would that make since it's the
configuration I've always used?Â* Oh, and my PF portable is loaded by a
micro SD card.Â* Or are you referring to the USB stick that I used to
install the latest data.fln file?Â* Maybe I should roll back to my
previous flarmnet file.
Dan, 5J
best,
Evan
Dan, 5J
Old June 10th 19, 09:50 PM posted to rec.aviation.soaring
Tango Eight
Hi Dan,
If the cfg file is correct, then it isn't any issue. I mentioned this possibility because it's fairly common. Guys put the update on an old USB or SD card that happens to have an old (or someone else's) cfg file on it... and whammo.
If the problem arose immediately after you updated the flarmnet file, then I would wonder about that. I'm not aware of problems here, but "undoing the last action you took" is worth investigating.
Dan, 5J
best,
Evan
Dan, 5J
Old June 10th 19, 10:58 PM posted to rec.aviation.soaring
Dan Marotta
Thanks Evan,
Next on my list is to replace the most recent flarmnet file with the
previous one.Â* Maybe the weather will improve tomorrow and I can try it out.
On 6/10/2019 2:50 PM, Tango Eight wrote:
Hi Dan,
Dan, 5J
best,
Evan
Dan, 5J
Dan, 5J
Old June 11th 19, 02:16 AM posted to rec.aviation.soaring
Ramy[_2_]
Flarmnet has no impact other than showing the contest number instead of flarm ID. So is the issue that flarm Target was showing up but not recognizable, or not showing at all?
Ramy
Unable to Update PowerFLARM Portable Firmware Dan Marotta Soaring 12 September 4th 17 02:45 AM
PowerFlarm Firmware Karl Kunz[_2_] Soaring 9 March 15th 17 02:44 PM
PowerFlarm Update Problem John Carlyle Soaring 14 April 15th 15 11:20 PM
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 03:13 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
