https://en.wikipedia.org/wiki/Slingsby_Grasshopper
The Slingsby T.38 Grasshopper is a British primary training glider built by Slingsby Sailplanes for the Royal Air Force. Role Primary glider Manufacturer Slingsby Sailplanes Limited First flight 1952 Introduction 1952 Primary user Royal Air Force Number built 115 The design is based on the pre-World War II German SG 38 Schulgleiter, modified to use the wing design of the Slingsby T.7 Kirby Cadet glider. The design was cheap to manufacture and was designed to be stored dismantled. The type was used by Air Training Corps Squadrons between 1952 and the late 1980s. The RAF designated the glider the Grasshopper TX.1 and the first order was for 65 aircraft which were delivered in 1952 and 1953. It was later followed by two further orders for an additional 50 aircraft, the final delivery was made in 1963. Launch is achieved through the use of a V shaped bungee or elastic rope pulled by a team of helpers. The glider can also be mounted on a pivoting tripod pointed into wind for the demonstration of controls. The Grasshopper is virtually identical to the EoN Eton. Specifications (Grasshopper TX.1) General characteristics Crew: 1 Length: 20 ft 8 in (6.3 m) Wingspan: 39 ft 0 in (11.88 m) Height: 8 ft 0 in (2.43 m) Wing area: 173.9 sq ft (16.16 m2) Aspect ratio: 8.73 Airfoil: Göttingen 426 Empty weight: 293 lb (132.9 kg) Gross weight: 550 lb (249.5 kg) Performance Stall speed: 30 mph; 26 kn (48 km/h) Never exceed speed: 80 mph; 70 kn (129 km/h) Wing loading: 3.10 lb/sq ft (15.13 kg/m2) * |
Miloch wrote in
news
https://en.wikipedia.org/wiki/Slingsby_Grasshopper The Slingsby T.38 Grasshopper is a British primary training glider built by Slingsby Sailplanes for the Royal Air Force. |
| Thread Tools | |
| Display Modes | |
| Valliant Air Command - L-4J Grasshopper - L-4J Grasshopper.jpg | [email protected] | Aviation Photos | 0 | March 5th 16 09:05 PM |
| CAF Mesa Batch 2 [05/45] - L-16 Grasshopper DSC_3907.jpg (1/1) | Indrek | Aviation Photos | 3 | January 20th 11 06:49 AM |
| Slingsby T.38 Grasshopper | XA310 | Soaring | 0 | December 25th 08 09:25 AM |
| CAC Grasshopper VH-BUG | Glenn[_2_] | Aviation Photos | 1 | April 8th 07 08:40 AM |
| A Tupolev grasshopper | HECTOP | Piloting | 4 | July 5th 04 09:57 AM |
