We have a '74 PA-28-180 - the first year this model was called an "Archer".
The cowl is not in the greatest shape, partly because of its age, and partly because one of the partners a few years ago landed on a runway that was about 18" too short and slid gently into the chain link fence at the end :-( Engine has had all the AD required inspections, etc, but the cowl did get a few bruises. We're into our annual as of yesterday and we have two problems that need to be dealt with ASAP. The first is that there is a slot in the back of the bottom cowl were it slides over the nosewheel strut. To keep the two halves of this slot from flapping around aafter it's installed, a (roughly 12- 15" long) aluminum "bridge" is screwed across the gap after the cowl is put in place, held in place by four screws and large trim washers that go through the fiberglass of the cowl and into the aluminum bridge. Two of these screws, at the outer ends of the bridge, are fine. The two nearest the slot, however, have been pulled away from the fiberglass, and now have nothing to go through. The corners of the fiberglass that they used to go through are simply gone. Someone at some point riveted a strip of aluminum to the back edge of the fiberglass, and the screws now go through this, but the aluminum strips are bent and the cowl no longer fits flush. We really need to remove the cludgy aluminum strips and redo the fiberglass so that the cowl fits better. Of course one problem is that this area is very oily from years of Lycoming Leakage (LL). My first question is, what is the best solvent to remove the oil so that a repair has a chance of adhering? I plan on cleaning everything and then thinning the glass a bit roughly 1.5 inches back from the edge, and then feathering and building up the area with glass cloth and epoxy to remake the back edge of the cowl (I've done a lot of boat building and repair, so this isn't rocket science to me, although I've always worked with polyester resins before). Next questions are, what is the best fiberglass for this? mat or cloth? S-glass, E-glass or something else? What epoxy is the best for repairs? Is there a kit available somewhere with everything (glass and epoxy) I need? If I want these quickly, what source should I use? I've seen complaints about Aircraft Spruce. Would Wicks be better for fast turnaround? Someone else? The other problem with the cowl is that there has been some delamination near the top of the low cowl where the propeller shaft opening is formed. This area has a lot of curvature, and there is a foam or balsa wood reinforcement bow epoxied into this area behind the curved opening. The cowl molding has pulled away slightly from this reinforcement bow. Not very much, but the A&P thinks that this should be closed up before the delamination propogates further. This is a more difficult problem, because there is very little clearance to get anything into the gap, there doesn't seem to be an edge to overlay a patch onto, and of course I have no idea how much oil has drifted in there that would prevent adhesion. My current plan here is to wash it out with some solvent to get most of any oil film out of there, and then inject a thin epoxy as deeply as possible into the crack with a syringe. Questions here are mostly about what solvent won't dissolve the reinforcing bow if it's a foam and not balsa wood, and where can I get a really thin, watery epoxy. Also, does anyone have any other ideas about fixing this area? Of course, we'd like to get this all done before the annual is done, so that the plane doesn't have to sit outside without a cowl. The last question is, is there someplace someone can recommend that we could have this done? I really don't have the time to do this, but will make the time in order to get it done right if necessary. I've thought of calling bodyshops that specialize in Corvettes, and boatyards, but they don't usually deal with weight issues. I can just see a quarter inch of heavy polyester and glass roving added to the inside of the cowl. I'd rather not have to log a major CG change. Anyway, any and all suggestions and advice would be greatly appreciated. I woke up early this morning thinking about this. Maybe I can go back to sleep now. Thanks, guys. -- Bob (Chief Pilot, White Knuckle Airways) |
Bob, simply injecting resin into a delamination void has zero chance of
holding up... Ditto for riveting aluminum strips to the lower cowl... You need to use a good grease cutter on the oil soaked areas (simple green, 409, etc.), followed by several scrubbings with liquid dish detergent and water, followed by spraying MEK on until it runs off (don't use bare hands for this stuff as it absorbs instantly through the skin and goes straight to the liver) Then you need to grind away the surface of any delamination (from either the inside or the outside depending on which side is the thinner part of the delamination) until you have removed the bad stuff and have a good layer left... The edges of the ground out pocket need to be tapered/scarfed to at least an 8:1 slope... Then you need to build up the removed material with unidirectional fiberglass and epoxy resin... Check the archives at rec.aviation.homebuilding for pointers on this (the Cozy MK-4 group is a good source of information)... Also, boat builder chat groups and personal web pages will have pictures of the proper way to layer the glass in, etc.. Lacking that, ask around for the local EAA chapter and someone there will speak fiberglass fluently... Also, the bottom lip needs to be ground back to solid material... The edge needs to be scarfed at an 8:1 slope... Then using .032 aluminum make a form to clamp to the cowl for shaping the new lip... Put a piece of saran wrap on the aluminum as a release layer... Then lay up new glass layers... Your surmise about non airplane fiberglass mechanics is likely correct, they may just slobber it on nice and thick... If you can find one that is building his own plane, that would be perfect... Other than that, shop around for a homebuilder, bound to be one near you... Or give me a jingle on the phone... None of this is hard once you have seen it done... Cheeers ... Denny |
We applied reflective aluminum tape to the inside of the nose bowls of our
Aztec to reflect heat away from the fiberglass. The nose bowls were covered with oily residue. We found that aerosol Brake Parts Cleaner worked great with no apparent degradation to the fiberglass. After we had them cleaned up, the aluminum tape adhered wonderfully. Stand the cowling on it's end, spray so the cleaner runs off, then wipe up any residue. What's left will evaporate. As for the holes and missing corners, you should be able to find a autobody shop or fiberglass fabrication shop that is able to refurbish that area of the cowl and drill new holes. Jim |
On Wed, 16 Feb 2005 05:52:03 -0500, "Bob Chilcoat"
wrote: We have a '74 PA-28-180 - the first year this model was called an "Archer". I have done a refurbish to all of the fibreglass on a PA28-140 which is almost blemish free after 5 years. The nosebowl on the cherokee is polyester resin so that was used in the repair. I prefer to work with epoxy but find out what was used originally on the cowl and use that or something compatible. degrease the bowl thoroughly with something that wont destroy the resin used. I used a cheap sprayon engine degreaser then hosed it off with water. detergent was used after that then I think Acetone just as a final cleaner. this didnt get all the grime out though it was dry and oil free so I sanded the surface with a disk sander until I was back to a layer of good glass. on the outer side of the bowl all the bog was sanded off with the rotary sander back to fibreglass. over the years the drumming from vibration had left the integrity destroyed and the glass was a little spongey to the feel. repair strategy was to use the existing glass work as the inner ply then layup 2 or 3 glass layers on each side, making a sort of 3 ply. it worked well and hasnt looked like deteriorating. the resin quantity is the old "not white not wet" guidance to good layups. I used a 1 inch wide chisel of wood to dapple the resin into the weave and a square piece of plastic ice cream bucket as the squeegee. keep the layups as light on the resin as possible consistent with good layup. to get a smooth outer layer I used a paste of resin and johnsons baby powder (talc) and squeegee'd this on to fill the weave but not much more than that. this was sanded back smooth and then it was painted. bob chilcott's comments on splaying are valid when repairing a missing section. remember that you can sand back a layup and add some more and it will be as good as a single complete layup. you can sand off something that didnt look too good and try again. when teasing around small corners having the weave at 45 degrees will aid the process considerably. If you have never done a layup then you should watch a video (Mike arnold's tapes of the AR5 are good) or watch someone actually do a layup. once seen it all becomes easy. a critical thing is to get the resin mix proportions exact and dont contaminate the mix with oils or water. get those right and it will set off perfectly. dont use glass cloth that has been wet. wetting glass cloth is a reason for condemning the piece and rubbish binning it. like anything aviation it isnt hard but needs to be done competently. Stealth Pilot |
Stealth Pilot wrote in
: to get a smooth outer layer I used a paste of resin and johnsons baby powder (talc) and squeegee'd this on to fill the weave but not much more than that. Run that one by me one more time? I haven't heard of this trick. |
On Wed, 16 Feb 2005 13:19:39 -0600, "James M. Knox"
wrote: Stealth Pilot wrote in : to get a smooth outer layer I used a paste of resin and johnsons baby powder (talc) and squeegee'd this on to fill the weave but not much more than that. Run that one by me one more time? I haven't heard of this trick. Most people use something like microballoons mixed with the resin to create a sandable finish. Corky Scott |
On Thu, 17 Feb 2005 08:16:21 -0500, Corky Scott
wrote: On Wed, 16 Feb 2005 13:19:39 -0600, "James M. Knox" wrote: Stealth Pilot wrote in m: to get a smooth outer layer I used a paste of resin and johnsons baby powder (talc) and squeegee'd this on to fill the weave but not much more than that. Run that one by me one more time? I haven't heard of this trick. Most people use something like microballoons mixed with the resin to create a sandable finish. Corky Scott thats it. I just checked the ingredients to the baby powder. talc, fragrance. sometimes I just do it for the fragrance :-) smells great while sanding it back. Stealth Pilot |
Stealth Pilot wrote: I just checked the ingredients to the baby powder. talc, fragrance. sometimes I just do it for the fragrance :-) smells great while sanding it back. Wear a dust mask. They took talc out of sheet rock compound because of health concerns over people breathing the dust. George Patterson He who tries to carry a cat by the tail learns something he can learn in no other way. |
In rec.aviation.owning Bob Chilcoat wrote:
: We have a '74 PA-28-180 - the first year this model was called an "Archer". : The other problem with the cowl is that there has been some delamination : near the top of the low cowl where the propeller shaft opening is formed. : This area has a lot of curvature, and there is a foam or balsa wood : reinforcement bow epoxied into this area behind the curved opening. The I'm assuming that you're referring to the top cowling, and the curvature between the cooling air inlets and the prop clearance hole. The shape that is embedded into the back of the cowling is screwed in from the front! There are three screw holes covered up on the front of the cowling: One in the center top of the prop clearance cutout and one on each side, on the up and down part of the cooling air inlets. This reinforcing shape was delaminating on my airplane (1968 PA-28-180) and what I did was to chop up some glass cloth into short pieces, soak them in resin, and pack the recess caused by delamination. This was 4+ years ago, and the repair is still in fine shape. Presumably some day it will need another repair, and I will probably remove the reinforcing shape completely and re-attach it. -- Aaron C. |
I like your idea of doing it yourself, as the time involved can add up
quicker than you realize. Anyone you pay to do it and who does it right will probably have to charge several hundred dollars to do it. You can do it I'm sure judging from what you have said. You sound like you have a good approach planned out. I did a fairly extensive repair on my Cardinal three years ago and the repair has held up so far. I had to replace the attachment points around the spinner where the top and bottom halves screw together. I would recommend you use Kevlar 49 instead of glass as it has better dampening properties than glass, and tends to last longer and not be as noisy. You can get a yard of it from Aircraft Spruce for under $20. Glass will be OK if you want to go that way. I agree that you should use epoxy instead of polyester, as it is much stronger. Spruce has a special one cheap that is specifically for Kevlar. I used it and the results seem to be very strong. It is very liquid and wets out the fabric well. I also agree with the others that recommend you grind away the delamination and then re-lay fabric in. Take your time, you'll be glad you did! Regards, Bruce Cunningham N30464 C177A Bob Chilcoat wrote: We have a '74 PA-28-180 - the first year this model was called an "Archer". The cowl is not in the greatest shape, partly because of its age, and partly because one of the partners a few years ago landed on a runway that was about 18" too short and slid gently into the chain link fence at the end :-( Engine has had all the AD required inspections, etc, but the cowl did get a few bruises. We're into our annual as of yesterday and we have two problems that need to be dealt with ASAP. The first is that there is a slot in the back of the bottom cowl were it slides over the nosewheel strut. To keep the two halves of this slot from flapping around aafter it's installed, a (roughly 12- 15" long) aluminum "bridge" is screwed across the gap after the cowl is put in place, held in place by four screws and large trim washers that go through the fiberglass of the cowl and into the aluminum bridge. Two of these screws, at the outer ends of the bridge, are fine. The two nearest the slot, however, have been pulled away from the fiberglass, and now have nothing to go through. The corners of the fiberglass that they used to go through are simply gone. Someone at some point riveted a strip of aluminum to the back edge of the fiberglass, and the screws now go through this, but the aluminum strips are bent and the cowl no longer fits flush. We really need to remove the cludgy aluminum strips and redo the fiberglass so that the cowl fits better. Of course one problem is that this area is very oily from years of Lycoming Leakage (LL). My first question is, what is the best solvent to remove the oil so that a repair has a chance of adhering? I plan on cleaning everything and then thinning the glass a bit roughly 1.5 inches back from the edge, and then feathering and building up the area with glass cloth and epoxy to remake the back edge of the cowl (I've done a lot of boat building and repair, so this isn't rocket science to me, although I've always worked with polyester resins before). Next questions are, what is the best fiberglass for this? mat or cloth? S-glass, E-glass or something else? What epoxy is the best for repairs? Is there a kit available somewhere with everything (glass and epoxy) I need? If I want these quickly, what source should I use? I've seen complaints about Aircraft Spruce. Would Wicks be better for fast turnaround? Someone else? The other problem with the cowl is that there has been some delamination near the top of the low cowl where the propeller shaft opening is formed. This area has a lot of curvature, and there is a foam or balsa wood reinforcement bow epoxied into this area behind the curved opening. The cowl molding has pulled away slightly from this reinforcement bow. Not very much, but the A&P thinks that this should be closed up before the delamination propogates further. This is a more difficult problem, because there is very little clearance to get anything into the gap, there doesn't seem to be an edge to overlay a patch onto, and of course I have no idea how much oil has drifted in there that would prevent adhesion. My current plan here is to wash it out with some solvent to get most of any oil film out of there, and then inject a thin epoxy as deeply as possible into the crack with a syringe. Questions here are mostly about what solvent won't dissolve the reinforcing bow if it's a foam and not balsa wood, and where can I get a really thin, watery epoxy. Also, does anyone have any other ideas about fixing this area? Of course, we'd like to get this all done before the annual is done, so that the plane doesn't have to sit outside without a cowl. The last question is, is there someplace someone can recommend that we could have this done? I really don't have the time to do this, but will make the time in order to get it done right if necessary. I've thought of calling bodyshops that specialize in Corvettes, and boatyards, but they don't usually deal with weight issues. I can just see a quarter inch of heavy polyester and glass roving added to the inside of the cowl. I'd rather not have to log a major CG change. Anyway, any and all suggestions and advice would be greatly appreciated. I woke up early this morning thinking about this. Maybe I can go back to sleep now. Thanks, guys. -- Bob (Chief Pilot, White Knuckle Airways) |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 01:04 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
