I've always had a well founded and severe fear of using any type of ice melt
product around our hanger entrance. As a farmer, I know what ammonium nitrate, ammonium sulfate, potassium chloride etc. are and what they can do to your equipment. Recently our FBO started selling an palletized ice melt made of ammonium sodium acetate, the dry prilled form of the liquid product that they spray on the runways as a ice preventative. Does anybody know the corrosive properties of ammonium sodium acetate? Thanks Jim |
Jim,
We use simple urea at Dulles Airport. Not sure how it affects the aircraft though. Michelle Jim Burns wrote: I've always had a well founded and severe fear of using any type of ice melt product around our hanger entrance. As a farmer, I know what ammonium nitrate, ammonium sulfate, potassium chloride etc. are and what they can do to your equipment. Recently our FBO started selling an palletized ice melt made of ammonium sodium acetate, the dry prilled form of the liquid product that they spray on the runways as a ice preventative. Does anybody know the corrosive properties of ammonium sodium acetate? Thanks Jim |
Urea has been used around my airport since the earth first cooled, and
I also use it... No evidence of any corrosion damage to any airplanes - the weeds do really well near the hangars, too... Denny |
I've talked to two different FBOs and a few IAs. They have all told me
that urea doesn't cause corrosion. The IAs work on a/c based at an airport that uses urea, and they see no difference in the airframes and such of those a/c flown during the winter when urea is in use and those that are hangered and only flown in "good weather". I also use it on the sidewalks and driveway where I live. Grass seems to like it much more than salt. Later, Steve.T PP ASEL/Instrument |
Thanks for the urea tip, but it primarily works best at or around freezing
temps, it's pretty ineffective much below 20 degrees, which here in Wisconsin is most of the winter months. I was able to find out that the potassium and sodium acetate products are corrosive and typically mixed with an anti-corrosive agent so they are able to be used around airports. Here's a quote from the USPS Chemical Engineer (why would the post office need a chemical engineer??!) Urea is also a common fertilizer nutrient. In its pure form, urea is not corrosive making it a good choice for use around airplanes. Urea must meet strict contamination regulations before being approved to use at airports. However, most of the urea sold for melting ice is considered an agricultural grade is not suitable for use in corrosion sensitive environments. This also goes to explain why urea fertilizer eats the SH*T out of anything steel here on the farm, everything we put urea in is either plastic, stainless steel, or wood. I don't know how it effects aluminum. Obviously airports are getting a purer form than the 46-0-0 that we use. Good to know so pilots don't just run down to their local co-op for some 46-0-0. Some fertilizer grades are also pelletized or coated with sulphur to make it easier to handle during humid weather. (Urea draws moisture from the air and turns to mush) The reason grass likes it is because it's main ingredient is Nitrogen and it contains no chlorides like salts do. Jim |
Boy I'm glad you said that.
After what I was told, I had gone and bought the ice clearing stuff at the local hardware store that is urea based. Glad I didn't take that to the airport. And, yeah, it is only good if you can get the ice to get wet so it mixes. Here in Ohio where I am, all it does is eat a hole straight down about 4 mm in dia when the temp is between 20-28. Below that, it takes a long time before it even melts in pit so it doesn't blow around. All I intended to use it for is to get the hanger doors open (ours are on rollers instead of being bi-fold). So far, when ever I get a chance to go to the airport, the doors are frozen shut (for those of us with north facing doors). Later, Steve.T PP ASEL/Instrument |
Urea from Agway sounds like just the ticket for keeping the front step clear. What's it like when tracked into the house? (Sorry for dragging this OT, but rock salt is hateful stuff on the lawn and in the front hall.) -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
"Jim Burns" wrote in message ... I've always had a well founded and severe fear of using any type of ice melt product around our hanger entrance. As a farmer, I know what ammonium nitrate, ammonium sulfate, potassium chloride etc. are and what they can do to your equipment. Recently our FBO started selling an palletized ice melt made of ammonium sodium acetate, the dry prilled form of the liquid product that they spray on the runways as a ice preventative. Does anybody know the corrosive properties of ammonium sodium acetate? Thanks Jim We started getting quite a few of our pups back from European operators with the cad plated parts very corroded. Turns out the Europeans were using some sort of new deicer stuff on their runways and all. Unfortunately I do not know what it was exactly, but you can do some testing on your own parts. Get some old screw hardware from your local mechanic and see what happens... |
"Blueskies" wrote in message news ![]() "Jim Burns" wrote in message ... I've always had a well founded and severe fear of using any type of ice melt product around our hanger entrance. As a farmer, I know what ammonium nitrate, ammonium sulfate, potassium chloride etc. are and what they can do to your equipment. Recently our FBO started selling an palletized ice melt made of ammonium sodium acetate, the dry prilled form of the liquid product that they spray on the runways as a ice preventative. Does anybody know the corrosive properties of ammonium sodium acetate? Thanks Jim We started getting quite a few of our pups back from European operators with the cad plated parts very corroded. Turns out the Europeans were using some sort of new deicer stuff on their runways and all. Unfortunately I do not know what it was exactly, but you can do some testing on your own parts. Get some old screw hardware from your local mechanic and see what happens... That pups should be pumps, as in hydraulic. http://www.parker.com/ag/pdf/abexbrochure.pdf in case you are interested... |
"Blueskies" wrote in message ... We started getting quite a few of our pups back from European operators with the cad plated parts very corroded. Turns out the Europeans were using some sort of new deicer stuff on their runways and all. Unfortunately I do not know what it was exactly, but you can do some testing on your own parts. Get some old screw hardware from your local mechanic and see what happens... That pups should be pumps, as in hydraulic. http://www.parker.com/ag/pdf/abexbrochure.pdf in case you are interested... Cadmium plating is routinely stripped from the base metal using an amonium nitrate solution, hence the corrosion. |
| Thread Tools | |
| Display Modes | |
| WeserFlug P.1003 Compared to V-22 Osprey | robert arndt | Military Aviation | 29 | December 2nd 03 07:23 PM |
