Source for db25 shell for locking pins on a Becker 4201?
Old June 28th 19, 03:06 PM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Default Source for db25 shell for locking pins on a Becker 4201?
Becker likes to use slide locks for the db25 connector on the back of the radio.
The ar3201 has a circular pin slide lock - the ar4201 a different locking "hook" hardware set.
Does anyone have a source for such hardware? I've looked in mouser and other online catalogs, but all I find are the standard
screw-in post connectors.
I'd replace the lock hardware on the radio, but suspect I'd have to completely disassemble it to put in new hardware.
Old June 28th 19, 05:16 PM posted to rec.aviation.soaring
Dan Daly[_2_]
This is what I used on my new-to-me AR4201; MHED-DS25S - D Sub Backshell: https://www.newark.com/mh-connectors...14_US%2Fsearch
Newark part number 61W9841 ; cost under $3USD/per. I'm surprised that the normal soaring suppliers don't stock them.
Cheers
Dan
Old June 29th 19, 12:28 AM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Ordered. Thanks!
Sarah
Cheers
Dan
Old June 29th 19, 10:27 AM posted to rec.aviation.soaring
Charlie Quebec
I just removed the factory screws and bracket, then got two of the inside threaded bolts from an old PC and screwed in. Worked great.
Old June 29th 19, 04:03 PM posted to rec.aviation.soaring
A couple of comments;
- Both Cumulus and Wings & Wheels have the Becker locking shells in stock. Unsure about the other vendors.
- While I am not in love with the Becker latching system, preferring the LXNav "bail" type instead, they both have one advantage over the common screw-in type. Which is you can connect/latch the Becker/Filser/LXNav connectors blindly in our tight instrument panel confines.
- See http://aviation.derosaweb.net/presentations/#wiring (slide 47) for details.
- John OHM Ω
Old June 30th 19, 12:00 AM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Thanks for the comments & presentation link. I didn't see the shell on W&W and I still can't find it on Paul's site.
But no problem... I have 2 coming in the mail from NJ.
Since you mentioned it (on the slide), know of a source for the "Filser/Dittel" sliding catch post-style shell?
That's the type used on my archaic AR3201. Maybe I should just buy a 4201.
Sarah
- John OHM Ω
Old June 30th 19, 02:14 PM posted to rec.aviation.soaring
That's the type used on my archaic AR3201. Maybe I should just buy a 4201..
Sarah
- John OHM Ω
The LXNav "bail" type bits for the equipment end of things was "easy" to find. See the link below. But the connector eludes me (other than for Centronics types). Anyone? Bueller? Bueller?
https://www.digikey.com/product-deta...AgkMEALw_wc B
For the record Wings and Wheels lists the Becker latching "shell" as the alternate term "hood". https://wingsandwheels.com/db25-conn...d-housing.html
Old June 30th 19, 02:40 PM posted to rec.aviation.soaring
PS - As to the Filser sliding type the link is shown below. Unlike the Becker sliding style which requires a special shell, this item is bolted to a standard DB25 connector (and shell). Enjoy!
https://www.newark.com/cinch-connect...SingleItem_ 1
- John OHM Ω
Becker 4201 soaringjac Soaring 4 April 25th 19 01:56 PM
Becker AR 4201 John Foster Soaring 15 October 6th 18 05:33 PM
FS: 5 Becker 4201 + 1 Becker 3201 + 1 Dittel FSG5 Handheld Ross[_3_] Soaring 10 April 4th 18 04:36 PM
FS: Becker 4201 Romeozulu Soaring 0 March 7th 14 11:21 AM
FS: Becker AR 4201 Don[_4_] Soaring 0 September 19th 12 05:16 PM
