TE Probe O-ring came off
Old June 29th 19, 05:31 AM posted to rec.aviation.soaring
Wade G
Default TE Probe O-ring came off
Looking for tips.
I pulled my ESA multiprobe out after flying today to discover the smaller O-ring did not come with it.
Any suggestions to fetching it. I can’t see it in there.
I have a replacement so would leaving the vanished ring in there cause any problem? A mild restrictor at the most?
Lastly, is there a better lube for the rings than oil from the side of my nose?
Wade
Old June 29th 19, 07:51 PM posted to rec.aviation.soaring
Darryl Ramm
I am trying to recall a multi probe with o-ring on the probe. Mine all have the o-rings internal.
If it is not supposed to be there I assume you should get it out. Dental tool/o-ring pick and a bright light. Pulled all the o-rings out of these mounts that way before. ESA have o-ring kits for the mounts, one I used came with silicone lubricant. Or use suitable silicone o-ring lube. (Eg At annual I would clean any dust/grit in mounts out with lint free wipes, inspect carefully, and apply a tiny amount of lube to the o-rings/probe and work around. Keep covered (but not air tight) when not in use and do not use extra lube daily). I am not sure if the nose wiping ritual helps or hurts. All that salt getting inside the mount.
Darryl
Old June 29th 19, 08:20 PM posted to rec.aviation.soaring
Wade G
I tried a hooked piece of safety wire to no avail.
Very slim chance the thing went flying when I pulled it out but being on black gritty pavement, no way to find it.
Wonder if sending some air through from the other end (with EVERYTHING disconnected from instruments) would be worth it.
And, unfortunately this discussion is starting to sound Freudian.
Wade
Old June 29th 19, 08:54 PM posted to rec.aviation.soaring
James Thomson[_2_]
EVERYTHING
Wade
There is some guidance on changing the adaptor o-rings (but not probe o-
rings) on the ESA website
https://www.esa-systems.com/en/suppo...tions-answers/
plus the option of a contact form for advice
Old July 3rd 19, 03:32 AM posted to rec.aviation.soaring
Charles Longley
Use DC4 to lube O-rings.
https://www.amazon.com/Dow-Corning-E...72280169&psc=1
Tow ring attachment? Waveguru Soaring 7 May 25th 15 07:50 AM
red ring of death larryo keeffecom Soaring 1 February 29th 12 03:50 PM
Second O-ring on a triple source probe - how to replace? AK Soaring 1 April 11th 08 04:12 AM
VW Flywheel O-ring [email protected] Home Built 0 April 6th 08 09:57 PM
Inspection cover and ring? Mike Restoration 1 October 2nd 03 04:51 AM
