Dassault Mystère
Old November 22nd 18, 04:03 PM posted to alt.binaries.pictures.aviation
Miloch
Default Dassault Mystère
https://en.wikipedia.org/wiki/Dassault_Myst%C3%A8re
The Dassault MD.452 Mystère is a 1950s French fighter-bomber.
After the success of the Ouragan, Dassault was working on a more advanced
machine based on it, which would take to the air in early 1951 as the MD.452
Mystère I.
The first prototype Mystère I was essentially an Ouragan with a 30-degree swept
wing and modified tail surfaces. Two further prototypes followed, powered by the
Rolls-Royce Tay 250 centrifugal-flow turbojet, an improved version of the
Rolls-Royce Nene, built under license by Hispano-Suiza, and rated at 28.0 kN
(6,300 lbf) thrust.
These three Mystère I prototypes led to two Mystère IIA prototypes, powered by
the Tay and armed with four 20 mm (0.787 in) Hispano cannon; and then four
Mystère IIB prototypes, which traded the four 20 mm (0.787 in) cannon for two 30
mm (1.181 in) DEFA revolver-type cannon. A Mystère IIA was the first French
aircraft to break Mach 1 in controlled flight (in a dive), on 28 October 1951.
The eleven preproduction machines that followed were designated Mystère IIC,
nine of which were fitted with the SNECMA Atar 101C axial-flow turbojet, rated
at 24.5 kN (5,500 lbf) thrust, while two were experimentally fitted with the
afterburning Atar 101F, with an afterburning thrust of 37.3 kN (8,400 lbf).
Role
Fighter-bomber
Manufacturer
Dassault Aviation
First flight
23 February 1951
Introduction
1954
Retired
1963 (France)
Status
Retired
Primary user
French Air Force
Produced
1951–1957
Number built
171
Variants
Dassault Mystère IV
Dassault Super Mystère
The French Air Force ordered 150 Mystère IICs, with the first production machine
flying in June 1954, being delivered in October of that year. The production
aircraft featured the twin 30 mm (1.181 in) DEFA cannon, an Atar 101D turbojet
with 29.4 kN (6,600 lbf) thrust, increased tail sweep, and revised intake
trunking and internal fuel tank arrangement. Top speed was 1,030 km/h (560 kn;
640 mph) at low level. Details of external stores are unclear, but a reasonable
assumption would be that they were similar to those of the Ouragan.
The last Mystère IIC was delivered in 1957, by which time the type was already
being relegated to advanced training duties. Aircraft design was moving very
quickly in the 1950s and even as the Mystère IIC was becoming operational, the
better Dassault Mystère IVA was flying. The Mystère IIC was very much an
interim type, though it did persist in the training role until 1963.
There were no foreign buyers for the Mystère II. As noted, the Israelis wanted
to buy 24 but changed their minds and bought Mystère IVAs instead. It appears
that the Mystère II was never used in combat.
Variants
MD 452 Mystère I The first of three prototypes was essentially an Ouragan with a
30-degree swept wing and modified tail surfaces. Two further prototypes
followed, powered by the 28.0 kN (6,300 lbf) Rolls-Royce Tay 250
centrifugal-flow turbojet.
MD 452 Mystère IIA Two prototypes powered by the Tay and armed with four Hispano
20 mm cannon.
MD 452 Mystère IIB Four IIB prototypes traded the four 20 mm (0.787 in) cannon
for two 30 mm (1.181 in) DEFA cannon
MD 452 Mystère IIC The standard production aircraft for the French Air Force,
with 150 delivered from June 1954. Eleven preproduction IICs were used for
operational evaluation and trials with SNECMA Atar 101C axial-flow turbojet and
the afterburning Atar 101F.
MD 453 Mystère IIIN A single Mystère prototype built with lateral intakes and a
two-seat cockpit, to continue development of the MD 451 Aladin initiated with
the MD 450-30-L modified Ouragan. First flown on 18 July 1952 the sole IIIN was
never fitted with a radar and was used for ejection seat trials once development
of the MD 451 was abandoned. The second and third prototypes were cancelled
before completion.
Specifications (Mystère IIC)
General characteristics
Crew: one
Length: 11.7 m (38 ft 5 in)
Wingspan: 13.1 m (43 ft 0 in)
Height: 4.26 m (14 ft 0 in)
Wing area: 30.3 m2 (326 sq ft)
Empty weight: 5,225 kg (11,519 lb)
Max takeoff weight: 7,475 kg (16,480 lb)
Powerplant: 1 × SNECMA Atar 101D axial flow turbojet, 29.4 kN (6,600 lbf) thrust
Performance
Maximum speed: 1,060 km/h (659 mph; 572 kn)
Range: 885 km (550 mi; 478 nmi)
Service ceiling: 15,250 m (50,030 ft)
Rate of climb: 23 m/s (4,500 ft/min)
Armament
Guns: 2× 30 mm (1.181 in) DEFA cannon with 150 rounds per gun
Rockets: 2× Matra rocket pods with 18× 68 mm (2.68 in) SNEB rockets each
Bombs: 900 kg (2,000 lb) of payload on four external hardpoints, including a
variety of bombs or Drop tanks
Pushers, pt 6 - Partenair S45 Mystere.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 March 6th 18 01:32 PM
Mystere IV Fabio Aviation Photos 0 July 28th 08 10:56 PM
MAE : Mystere IV jmp Aviation Photos 0 March 20th 08 09:38 PM
