TE probes?
Old July 11th 19, 03:54 AM posted to rec.aviation.soaring
soaringjac
Default TE probes?
Might be a dumb question, but can you just purchase any old TE prob and throw it in your glider or does it have to be calibrated to your specific glider?
Old July 11th 19, 05:09 AM posted to rec.aviation.soaring
Tango Whisky
Default TE probes?
No calibration required, TE probes work for any glider.
Old July 11th 19, 06:01 AM posted to rec.aviation.soaring
soaringjac
Default TE probes?
Thanks!
Old July 11th 19, 07:22 AM posted to rec.aviation.soaring
Steve Thompson[_2_]
Default TE probes?
Worth a read of
https://www.esa-systems.com/en/products/#total-energy-
probes
Thanks!
Old July 11th 19, 03:03 PM posted to rec.aviation.soaring
Gianni Isotope
Default TE probes?
Of course, any old TE probe will not necessarily fit your specific glider -- pay attention to the inlet port diameter sizing of aftermarket probes.
Old July 11th 19, 03:21 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default TE probes?
TE probes can be used with any glider. Make sure the Port on the fin is the same as your current probe, diameter and inputs.
http://www.craggyaero.com/esa-systems.htm
Richard
www.craggyaero.com
Old July 12th 19, 03:43 AM posted to rec.aviation.soaring
soaringjac
Default TE probes?
Richard
www.craggyaero.com
Thanks Richard!
Old July 11th 19, 06:42 PM posted to rec.aviation.soaring
john firth
Default TE probes?
yes, a T.E probe will work with any glider, but the tail can have significant effect on the accuracy of the compensation.
A large, thick section tail (eg Kestrel 19) will reduce the Cp
of the probe, so it under compensates.
The further ahead of the tail the tip is, the less is the influence of
the pressure field of the tail.
JMF
soaringjac
Default TE probes?
JMF
Thanks John!
TE probes 4Z Soaring 3 June 18th 13 05:49 PM
WTB CHT probes [email protected] Home Built 6 August 11th 04 06:46 PM
WTB CHT probes [email protected] Aviation Marketplace 6 August 11th 04 06:46 PM
WTB CHT probes [email protected] Owning 6 August 11th 04 06:46 PM
Why use TE probes at all? Robert Soaring 1 May 8th 04 12:27 AM
