Fanny packs for baleout
Old July 21st 19, 04:21 AM posted to rec.aviation.soaring
Default Fanny packs for baleout
I've started carrying my Inreach in a fanny pack. They are cheap, and if rotated so the pack lies between parachute straps, offer a comfortable way to keep safety equipment attached in the event of a baleout.
Old July 21st 19, 12:27 PM posted to rec.aviation.soaring
Be aware there are several ways to put on a fanny pack that can interfere with parachute deployment. Best thing is one of those pouches designed and built by a rigger(even if you have to buy one from the 20 year lifescam guy.)
Old July 21st 19, 04:13 PM posted to rec.aviation.soaring
JS[_5_]
Our local rigger has added hard points to a few parachutes, and built pouches specifically for your tracker that keeps it secure, in a good place to see the sky, and will not interfere with parachute deployment.
It can be made much smaller than the pack from the "after 20 years cut the suspension lines" guy, so you won't notice the tracker on your shoulder.
Doing the mod at repack time seems easiest.
Old July 21st 19, 05:07 PM posted to rec.aviation.soaring
A fanny pack on the front of your torso may not be the best bet, I will agree (never had to bail...) it is better than comm's hitting the ground with the fuselage....
Sorta depends on size of comm's.
Likely way better solution.
Trying to never test any solution out.....
Whatever you chose, hope you never have to test it out.
If you do test it, hope it works well....
Photo Fanny Glenn[_2_] Aviation Photos 1 September 25th 10 04:44 PM
How long are our re packs good for? Viperdoc[_6_] Aerobatics 1 April 22nd 09 12:31 AM
Crash.........fanny fox[_2_] Aviation Photos 2 May 17th 08 09:05 PM
Grandma's ol' fanny friend HECTOP Piloting 4 May 12th 04 05:32 PM
Jeppesen- no more Express Packs? Colin Kingsbury Instrument Flight Rules 4 December 2nd 03 09:41 PM
