DG-1000 - confusing W&B information in the pilot's manual
Old July 23rd 19, 09:48 PM posted to rec.aviation.soaring
India Four Two
Default DG-1000 - confusing W&B information in the pilot's manual
My gliding club has a DG-1000S. We have an overly complex spreadsheet which we use to determine permissible cockpit weights and the number of tail weights required (0-12 Kg). Part of the complexity is that the spreadsheet has to allow for 18 m or 20 m wings, plus wet or dry configuration.
Another member and I have taken on the task of producing a simplified spread. I have a lot of experience with W&B calculations, so I don't foresee any difficulty in producing a suitable new spreadsheet. I have been experimenting with producing a graph with front seat weight on the X axis, CG location on the Y axis and lines showing different rear seat weights from zero to the maximum allowed.
The difficulty we are having is in understanding the pilot's manual. It seems to be a mixture of mandated weights plus suggested weights to keep the CG within an "acceptable" range. In places it is incomprehensible.
I thought initially, that it might be poor translation, but I discovered that the German manual is equally bad!
I'm wondering if there are any DG-1000 operators in this group who might like to give some advice.
Old July 24th 19, 06:26 AM posted to rec.aviation.soaring
We have a DG1000S that we use and have a super simple spreadsheet that includes a graphical picture of the CG location and will turn RED if you are outside limits. Send me a personal note and I'll send an excel file your way.
-Kevin
Old July 24th 19, 02:38 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I created a weight and balance spreadsheet that I use with our DG-1000S. I use it to verify CG using passenger weights, tail and nose weights, and water ballast. I'd be glad to email it to you for your reference upon request.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Pilot Information NVAV 40 Fly-In Aviodrome EHLE this weekend Zier & van de Steenoven[_2_] Home Built 0 May 18th 11 10:13 PM
Need a Jeppesen Instrument Pilot Manual [email protected] Aviation Marketplace 0 March 4th 05 11:48 PM
Pilot Operating Manual for Mosquito Dave Boulter Soaring 0 February 3rd 05 06:38 AM
Trimble TNL 1000 DC Installation Manual Brian Cox Owning 4 June 11th 04 02:17 PM
1000 hours in PW5 by Oz Pilot Charles Yeates Soaring 3 December 9th 03 04:39 AM
