"FAI Combined" Class?
Old July 26th 19, 06:06 PM posted to rec.aviation.soaring
Default "FAI Combined" Class?
Hey all - I've been seeing this terminology around, such as for next month's Region 10, but it doesn't line up with the current rules - can anyone clarify what this means?
Old July 26th 19, 06:15 PM posted to rec.aviation.soaring
Regional organizers have a lot of flexibility in setting up classes based upon entries.
The "FAI handicapped class" is a handicapped class that may accompany another class such as Sports. This is commonly used when there are not enough ships for a Std or 15M so they get combined and handicapped to allow ships to be competitive.
UH
Old July 26th 19, 06:18 PM posted to rec.aviation.soaring
Basically it means there are not enough Standard class or 15m class pilots to hold seperate classes. So they combine and then handicap them to make it fair. Sorta of a sports class limited to modern day 15m span ships.
CH
Old July 26th 19, 06:39 PM posted to rec.aviation.soaring
Thanks for the responses - the confusion is caused by the terminology, since the rules refer to "FAI Handicapped". With the ever-present angst over the handicaps themselves!
Old July 27th 19, 12:55 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
The term is pretty flexible. At R11 FAI Class is regularly used to denote basically a Sports Class competition that permits water ballast.
As an aside, this year R11 also included by waiver a handicapped distance “California Grand Prix” task. I think it was universally viewed as a fun format by the participants.
Andy Blackburn
9B
Old July 27th 19, 01:54 AM posted to rec.aviation.soaring
Regardless of handicaps.....I still say about 90% is the nut behind the stick, and go from there. A good pilot in a decent ship will likely be near the top anyway.....
Weather or geographic may skew handicaps a bit.....but they're usually pretty decent.
Be the "Hot Air Champion" at the Standard or Sports Class NationalsJune 20 - July 1 Chuck Lohre[_2_] Soaring 1 May 13th 19 12:15 AM
Nephi 2018 Hosting Combined Sports Class Nats and Regionals - ComeFly With Us! [email protected][_2_] Soaring 4 July 19th 17 06:28 PM
Is a state record for sports class triangle a "handicappeddistance"?? Spam Soaring 10 August 29th 09 10:45 PM
ARCUS - "THE ULTIMATE BENCHMARK OF THE TWO SEATER CLASS" johnhamish Soaring 3 August 4th 09 07:50 PM
Cancel " B747 Loses All 4 Generators Due To Clogged Sink In 1st Class" Gig 601XL Builder[_3_] Piloting 10 January 14th 08 06:48 PM
