Mistral-C vs DG-100
Old July 26th 19, 08:39 PM posted to rec.aviation.soaring
calin fagarasanu
Default Mistral-C vs DG-100
Hi all!
I know this kind of subject is boring and the gliders are old news but I am unable to decide which one to buy hence I am asking for help. There are so many other types but because I don't want to loose myself in too many details, I'd appreciate if you could help me compare this two only.
On one hand Mistral-C is:
+stable
+has a safe elevator
+has good visibility
+has both launching hooks
+some aerobatic ability
+easy rigging
but
-the landing gear is very close to the belly and I'm afraid it will be damaged in case of out-landing
-demand is not too high in case decide to sell
Unknowns:
Gel-coat resistance
Spare parts availability
Autonomy - how far can it fly
On the other hand DG-100 is:
+well known with still some demand (not sure)
+maintenance is there
+good gel-coat
+landing gear clearance is high
+better index +4
but
-visibility is poor for the 2 piece canopy (this is what I've found and for my budget)
-has all moving tail which I never flew and understand it is a safety concern
-belly hook only
Please add to this list.
Thank you,
Calin
Old July 27th 19, 07:19 AM posted to rec.aviation.soaring
Mike C
On Friday, July 26, 2019 at 1:39:43 PM UTC-6, calin fagarasanu wrote:
Hi all!
+stable
+easy rigging
but
Unknowns:
Gel-coat resistance
+good gel-coat
+better index +4
but
-belly hook only
Thank you,
Calin
My DG100 did not have a full flying stab, but I owned a sailplane that did (Phoebus C) and it was not a problem. I never thought my two piece canopy gave me poor visibility, and the CG hook was not a problem. I do not know anything about a Mistral C, but the DG is a good sailplane and very comfortable. I would arrange for a test flight before finalizing the deal though.
Good luck Calin.
Old July 27th 19, 07:28 PM posted to rec.aviation.soaring
Matt McBee
I have a DG-101 with conventional tail and one piece canopy. I can say that aerotow with the CG hook has been a total non-issue for me so far. Takeoffs are easy, just remember to follow the flight manual’s guidance. I mine, the trim should be set full forward for takeoff. I don’t know if this is true for the -100.
I have found the -101 to be a docile and responsive glider with very gentle and forgiving stall characteristics.
The airbrakes are only moderately effective, however.
Matt
Old July 28th 19, 04:01 PM posted to rec.aviation.soaring
Matt
The most important thing about buying a glider is to buy one that you know from reputation will sell well when you decide to upgrade - which you will at some stage as long as you stay in the sport. The glider market is pretty knowledeable so a glider that keeps it value does so for good reasons and when a glider type doesnt have that good reputation then there are also good reasons for it. Clues often are things like it not having sold many examples from new or coming from a factory that is no longer in business. Speaking as one whose first GRP glider was a Diamant 18 - but it was OK in the end because one of my syndicate partners wrote it off (shame about his fractured leg 'though)
Old August 15th 19, 05:24 PM posted to rec.aviation.soaring
Well, for the DG-100 you'll have to pay a subscription every year to get any service from the DG factory...
The Type Certificate for the Mistral C is now owned by Eichelsdorfer. You'll find the PDF Flight Manual (in German) here https://www.flugzeug-eichelsdoerfer.de/service.html
Old August 16th 19, 02:41 PM posted to rec.aviation.soaring
Senna Van den Bosch
Op zaterdag 27 juli 2019 20:28:31 UTC+2 schreef Matt McBee:
Matt
This is true for my DG-101 as well. I don't weigh much so on takeoff roll it set the trim full forward until I reach about 20m above ground and 100+ km/h, I set my trim halfway, to get the extra pitch from the trim tab.
Old August 20th 19, 10:39 PM posted to rec.aviation.soaring
Charlie Quebec
Any belly hook DG needs full down trim for takeoff. Nose hook not so much.
Old August 26th 19, 02:23 PM posted to rec.aviation.soaring
Andreas Maurer[_2_]
On Tue, 20 Aug 2019 14:39:20 -0700 (PDT), Charlie Quebec
Neither DG-300, nor DG-600, nor DG-800 need full down trim for an
aerotow. All of them belly hook.
I haven't flown DG-100 nor DG-200.
Cheers
Andreas
p.s.
We converted both of my club's DG-300s to nose hooks (due to German
legislation), so we could compare both hook positions on the same
gliders.
Absolutely NO trim change if the nose hook was used instead of the CG
hook.
Old August 15th 19, 07:21 PM posted to rec.aviation.soaring
I owned Mistral-C now own DG300.
Buy DG-100. It will outperform Mistral visibly.
Try cockpit for visibility but bear in mind many people fly with such canopies (not only dg100) and it is a non issue for them.
Mistral has manual connectors (not sure if dg100 is automatic).
S
Old August 16th 19, 02:38 PM posted to rec.aviation.soaring
Senna Van den Bosch
S
The DG-100 has l'hotellier connections, I fitted sleeves on mine this winter instead of those small pins for much easier rigging.
MISTRAL -C manuals SP[_3_] Soaring 0 January 17th 14 11:47 PM
MAE : mistral jmp Aviation Photos 0 March 20th 08 09:44 PM
MAE : mistral jmp Aviation Photos 0 March 20th 08 09:30 PM
MAE : mistral jmp Aviation Photos 0 March 20th 08 09:28 PM
Mistral C [email protected] Soaring 1 October 23rd 07 08:30 PM
