Clearance with an Odd Intersection
Old February 24th 05, 06:16 AM
Marco Leon
Default Clearance with an Odd Intersection
Has anyone received a route clearance that included an intersection that was
only on an approach chart and not in an Enroute Chart?
Flew IFR from FRG to GON with the following clearance: Farmingdale Three,
radar vectors BDR, direct MAD, MAD 126 radial to MONDI, direct.
For the life of me I couldn't find MONDI on the enroute. However, it was in
my (up-to-date) Garmin 430 database and it was pretty much on the way
(albeit a bit of a dogleg) so I didn't make it an issue. Turns out MONDI is
only on the KGON ILS RWY 5 and it's not even an IAF. The GPS RWY 33 was the
active approach which made it even more difficult to figure out.
Is this commom anywhere else? Should they have told me it was only on an
IAP chart? Are all the fixes on any of a given airport's approach charts
fair-game to include in an enroute clearance?
Regards,
Marco Leon
Old February 24th 05, 07:40 AM
Stan Gosnell
"Marco Leon" mleon(at)optonline.net wrote in
that was only on an approach chart and not in an Enroute Chart?
Sure. The ATC specialist who figures out the clearance may not even know
what charts it's on. You have to be flexible.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old February 24th 05, 12:39 PM
Marco Leon
"Stan Gosnell" wrote in message
So if I had queried the controller, then we'd have both been in the dark?
Sounds like we would have spent quite a bit of time looking. Well, if I have
to spread out my IAP charts, then I will. *sigh*
Marco
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old February 24th 05, 12:58 PM
On Thu, 24 Feb 2005 07:39:25 -0500, "Marco Leon"
Something everyone should do before every instrument flight.
Here's some advice. Never launch on a clearance you have not
thoroughly reviewed for accuracy, fix by fix, right to the ground.
That way, you won't find yourself airborne reworking your clearance to
nowhere out with a controller (assuming your radio is working at the
time).
Old February 24th 05, 03:48 PM
Ron Rosenfeld
On Thu, 24 Feb 2005 07:39:25 -0500, "Marco Leon" mleon(at)optonline.net
Had you queried the controller about the location of the intersection, he
would be able to give you coordinates.
Old February 24th 05, 03:53 PM
Marco Leon
I did review them but I concentrated on the GPS 33 considering the winds
were 310. To be honest, I didn't think I needed to scour the approach charts
to verify my enroute clearance. Besides, the routing as mapped out on the
GPS verified that it was not a "route-to-nowhere" which is why I took off. I
also had another intersection in mind right next to it (BOROS) that was on
the enroute charts that I can follow if there was a mistake.
Regardless, I agree with your advice that one should know their entire route
clearance before departure.
Marco
have
time).
Old February 24th 05, 03:56 PM
Marco Leon
"Ron Rosenfeld" wrote in message
As in LAT/LONG coordinates or radial fixes? Hadn't thought of that. I'll try
next time.
Marco
Old February 24th 05, 04:04 PM
Michelle P
Marco,
If you filed /G then the controller will not even ask. They know it is
in the Nav Database.
Michelle
Regards,
Marco Leon
Old February 24th 05, 04:05 PM
Stan Prevost
"Marco Leon" mmleon(at)yahoo.com wrote in message
try
next time.
The Garmin should also be able to give you that info, although knowing
lat/long won't help you find it on any chart, assuming that it is not on the
enroute as you said.
Old February 24th 05, 04:13 PM
Marco Leon
Now THAT makes sense. Is that a common thing with the air carriers?
Marco
"Michelle P" wrote in message
link.net...
Marco,
Michelle
was
in
is
Regards,
Marco Leon
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 04:55 AM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
