A-10s Come To The Rescue Of Desperate Troops In Afghanistan In This Awesome Gun Camera Footage
Old January 6th 19, 03:08 AM posted to alt.binaries.pictures.aviation
Miloch
Default A-10s Come To The Rescue Of Desperate Troops In Afghanistan In This Awesome Gun Camera Footage
more at
http://www.thedrive.com/the-war-zone...camera-footage
I was talking to a Joint Terminal Attack Controller recently who spent a lot of
time in Afghanistan. We were discussing the different platforms that are
lifesavers to troops in contact with the enemy. Obviously, the A-10 came up as
he made it very clear that the airframe-gun combo that makes up the A-10 is
incredibly powerful, especially when trying to surgically take out Taliban
fighters operating very close to friendly troops and/or in urban environments
where the chances of harm to innocent bystanders is really high. He pointed me
to a video he said was a great example of what this looks like, so I thought I
would share it with you and break it down a bit.
The setting of the video is above a village in Afghanistan, one surrounded by
steep mountains and made up of very similar looking low-rise structures that are
so prevalent in the country. In it, troops are under direct fire from fighters
taking cover around a number of buildings close by. A section of A-10 Warthogs,
callsign HOG 01 and HOG 04, have arrived overhead to give much needed close air
support to American soldiers that have found themselves in an increasingly dire
situation.
What comes next are a number of gun runs in which the A-10 pilots rapidly employ
their extremely potent 30mm GAU-8 Avenger cannons against the nearby fighters
with great precision. The voice you are hearing requesting the strafing runs is
the JTAC on the ground, callsign NIGHT OWL.
To help you interpret what you are seeing in the A-10's Heads Up Display (HUD),
above is a screencap from the video. Here is the important information it is
displaying in regards to what is going on. The 323 on the left is the airspeed
in knots. Across from it, the 4860 is the barometric altitude. Below it is a -9,
which means the aircraft is in a nine-degree dive. The 590 below that in the
corner right stack is the radar altimeter's altitude, so the true height above
the ground in this case. The next three lines have to do with steering points,
which can include tagged locations on the earth's surface and their time and
distance to the aircraft's present location. The bottom number is the current
time.
At the center bottom of the screen is the heading, with the jet pointing north.
ARM means the master arm is on and the aircraft is ready to employ its weapons.
Above that is the selected weapon profile and the quantity and type of weapon.
In this case, the aircraft shows 950 rounds of high-explosive incendiary 30mm
ammunition ready to fire. The upper left figure is the G-force on the aircraft
at any given moment. In this case 1.4G.
In the center is the pitch ladder with the gun's aiming reticle towards the top.
Once in firing range, the inner circle highlight begins to diminish, with the
approximate range to where the gun is pointing, or the constantly computed
impact point on the ground, showing in miles. In this case 1.5 as in 1.5 miles.
The little ball-bar inside of the reticle is the velocity vector showing where
the aircraft is headed.
With all that being said, here's the video:
https://youtu.be/EHMbkKi-QYo
more at
Avia BH 11: The Guy Was Desperate... - 1 attachment Transistor Bubblezap[_2_] Aviation Photos 0 October 20th 09 07:20 PM
Camera mounts for small digital camera kestrel254 Soaring 5 August 19th 08 04:03 PM
US Army must be really desperate! noname Military Aviation 0 May 24th 04 06:54 PM
Bush must be really desperate! noname Military Aviation 0 April 16th 04 04:45 PM
