Ogar parts source
Old August 7th 19, 06:34 PM posted to rec.aviation.soaring
Erin Quilter
Default Ogar parts source
We need a source for the tail wheel control cable for a 1977 SZD-45A Ogar glider.
Urgent! Please respond soon.
Contact Erin OR Joanie
Smiling Aviation
Delta, CO
970-874-5181
Old August 7th 19, 10:04 PM posted to rec.aviation.soaring
Have you check with an A&P who has Nico-press tool, correct cable and sleeves? Replacing worn or broken cables is a common thing for most any A&P mechanic.
He/she will know how to proof load replacement cable, if that is necessary/required.
JJ
Old August 7th 19, 10:08 PM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, August 7, 2019 at 10:34:57 AM UTC-7, Erin Quilter wrote:
We need a source for the tail wheel control cable for a 1977 SZD-45A Ogar glider...
Your best bet is to carefully measure the existing cable assembly and have it replicated by Aircraft Spruce or McFarlane. Typically you'll have one end finished and the other raw, and use field-installable terminations such as nicopress fittings to finish off the cable once you've fished it through all the pulleys, guides, fairleads, and etc.
Contact me off-forum if you'd like specific guidance about the process.
Thanks, Bob K.
bob at hpaircraft dot com
Old August 8th 19, 06:18 PM posted to rec.aviation.soaring
Geoff Minors
Smiling Aviation
Delta, CO
970-874-5181
I have a Ogar interested in contacting you
Geoff.
Anyone know of a source for Blanik L-13 parts? [email protected] Soaring 2 April 2nd 09 07:55 PM
Parts source for 1-26 Roger Kelly Soaring 2 April 27th 05 04:05 PM
Source of Piper Parts Mike Noel Owning 2 June 25th 04 09:04 PM
Wanted: Mini-500 spare parts source Mr.Twistair Home Built 4 January 24th 04 12:29 AM
Wanted: Mini-500 spare parts source Mr.Twistair Rotorcraft 4 January 24th 04 12:29 AM
