Tire pressure monitor
Old August 10th 19, 07:10 PM posted to rec.aviation.soaring
Phil King
Default Tire pressure monitor
Has anyone tried using a tire pressure monitor cap in place of a regular
dust cap on a glider tire?
There are at least two types - simple pneumatic ones that show
green/amber/red or ones with wireless technology to display remotely.
I'm thinking the simple one would be really useful provided it will fit
within the wheel fairing. I think it would be a non-starter for most
glider tail wheels but probably OK for the main wheel.
I would appreciate any constructive advice about this especially from
someone who has tried it.
Old August 11th 19, 03:07 PM posted to rec.aviation.soaring
Phil, do a quick search for TPM. There are good threads with info from 2008 and again in 2017.
I tried three different version and while they worked ok most of the time, all three systems would lose the signal at times.
Old August 11th 19, 05:10 PM posted to rec.aviation.soaring
AS
Michael - I think Phil is talking about this style:
https://www.amazon.com/Pressure-Moni...66788116&psc=1
and not the RF style which would monitor all of your vehicle's and trailer's tires remotely.
Uli
'AS'
Old August 14th 19, 03:28 AM posted to rec.aviation.soaring
bumper[_4_]
On Tuesday, August 13, 2019 at 6:45:05 AM UTC-7, Phil King wrote:
The only threads I found were about trailer tires rather than glider
tires. Anyone any experience of using a monitor on a glider tire?
Phil King
The problem with most TPMS systems, at least as they might be applied to a glider main tire, is they screw onto the tube's valve stem. In the limited number of gliders I've owned, there is no clearance for them.
I have them on my motorhome and can monitor the glider trailer as well. In that application they make a lot of sense as both tire pressure and temperature are displaced and have set points to trip an alarm. Then I can pull over, check things, and hopefully make necessary repairs before tire pieces depart.
The potential advantage for a glider seems about nil to me. In the unlikely event you have a leaking tire, you are going to land with it anyway, one way or another. You are probably not going to roll the emergency vehicles in any case, so the only advantage would be knowing you've got a low tire or flat in advance. Given that unlikely eventuality (I've only ever had a tailwheel go flat), it doesn't seem like a TPMS would be worth the bother, even if the sensor did have clearance to fit.
Once had a brake caliper freeze to the rotor on my Husky after playing in the snow off road. I knew about it as the Husky veered off a fair amount on take off from the snow covered road and I glanced at the wheel to see it wasn't turning, basically a ski. Landed back home on the unpaved runway at Minden on one wheel, when the locked-up wheel came down it broke free without fuss.
Old August 14th 19, 09:31 AM posted to rec.aviation.soaring
Phil King[_2_]
I guess I've not made it clear why I would want a TPM on a glider tire.
My thought is that when checking the glider before flight one action
should be to check the tire pressures. This is a time consuming process
- find pressure gauge, maybe find extension, take off dust cap, fit
gauge (and extension), read pressure, (remove extension,) replace
dust cap, repeat for each tire (three tires on some types). Each time
you do this you remove some air from the tire and with a small tire this
can be significant.
Much simpler to look at the TPM and check that it is showing green!
For a glider I can't see any advantage in having the wireless sort with a
read out in the cockpit. Of course for a trailer it's a great idea.
Old August 14th 19, 12:17 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
A search on "tyre pressure monitor cap" shows that shops on Amazon UK
sell them - a four-pack costs less than GBP 2.00. They look as though
they are a bit fatter and longer than the brass tyre caps on my glider,
but at the price its probably worth trying them, even if they do end up
on your car or trailer.
Martin | martin at
Gregorie | gregorie dot org
Old August 14th 19, 02:45 PM posted to rec.aviation.soaring
Phil King[_2_]
UK
Thanks Martin.
There are several different types on the market. I was looking for
anyone with experience of using them on gliders who could save me the
time required to try different ones and find a good one. I've actually
bought some rather more expensive ones off eBay (3 quid each).
Some of the cheap ones have had very bad reviews because they don't
seal well and let the air out of the tyre. If anyone is interested to know
how I get on then I can post the results back here in a few weeks time.
Old August 14th 19, 03:19 PM posted to rec.aviation.soaring
Dan Marotta
I believe you are over complicating this.Â* My advice:Â* Just look at the
tires.Â* You can tell if they're too low to fly.Â* That's worked for me
for almost 50 years.
UK
Thanks Martin.
Dan, 5J
Tire Pressure Monitoring Systems for Trailers AS Soaring 6 July 11th 18 04:00 AM
PW-5 Main Tire Pressure? JohnDeRosa Soaring 3 June 23rd 13 09:38 AM
Accurate tire pressure gage? Kurt Thams Soaring 6 September 25th 12 11:17 PM
Tire tread wear vs inflation pressure Ben Jackson Owning 22 October 6th 06 04:35 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
