static thrust in pounds produced by tail rotor????????
Old February 26th 05, 04:35 AM
Default static thrust in pounds produced by tail rotor????????
Hi
I need a perspective so this is a general question . If a 6 foot dia.
tail rotor is turning 2500 rpm how many pounds of static thrust at a
particular pitch angle would be produced???? And is that for a flat
rotor blade meaning no helical twist. Any senario close to the above
would be a big help. I want to build a variable pitch rotor and need to
get an idea on the thrust output .
Thanks ED
Old February 26th 05, 02:03 PM
Beav
Hi
That would depend on the chord and aerofoil section of said rototr blade.
Given all those values, it wouldn't be difficult to do the sums.
May I suggest a book on aerodynamic principles and mathematics? And no, I'm
not being funny, I'm being serious because without some grounding in the
basics, you're going to struggle finding answers that are simple to find
inside a calculator.
Beav
Old February 26th 05, 06:00 PM
The chord and airfoil variable if in realistic proportion would have a
small effect on thrust output , but would have a huge effect on fuel
cost over the life of the craft . I was looking for a short answer to
a general question that was perhaps common knowledge in this group .
Thanks ED
Old February 27th 05, 12:41 PM
Beav
And what would you consider to be "realistic proportions"? Is a high aspect
ratio realistic, and how high is high? Is a low aspect ratio more realistic
and if so, what IS low aspect?
I was looking for a short answer to a general question that was perhaps
And obviously you're not interested in doing any real research.
Beav
Old February 27th 05, 03:05 PM
Heli-Chair
you can get a rough estimate if you make a guess of the power going to
that tail rotor. there are varying numbers depending on helicopter but
you can assume 15% of the total engine power delivered goes to the tail
rotor. then you can use the equations below to estimate the number:
assume 400 hp helicopter engine, operating at max power
power to tail is 15% of 400 or 60 hp
power loading (PL) on a 6 foot disk is about 2.1 [hp/ft^2]
thrust loading (TL) is calculated using the following:
TL=8.6859 * (TL^-.3107) [lb/hp]
in this case, TL=6.89 pounds per horsepower
so thrust is approximately 400 pounds
Old March 8th 05, 11:08 PM
Thankyou Heli-Chair for the insight. ED
to
but
tail
Old February 28th 05, 06:27 PM
Bill Chernoff
Helicopter Performance, Stability, & Control, Ray Prouty, ISBN 0-89464-929-9
Old March 8th 05, 11:11 PM
Thanks Bill,,, ED
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
RV-7a baggage area David Smith Home Built 32 December 15th 03 04:08 AM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
