LS3 LS4 Differences
Old August 24th 19, 03:55 AM posted to rec.aviation.soaring
Default LS3 LS4 Differences
Hello, Leaning toward an LS3 or LS4 for my first glider. Are there any practical differences or are they very similar?
How about the flapped 3a? These seam to be the more available and are priced a bit lower?
Also how long does a paint finish typically last if gelcoat removed and refinished?
Thx you for the advise!
Old August 24th 19, 04:55 AM posted to rec.aviation.soaring
John Foster
LS3 is a flapped glider in 15M class. LS4 does not have flaps, and is in Standard class.
Old August 24th 19, 05:13 AM posted to rec.aviation.soaring
There has been much written about both of these gliders. If you use the search feature you'll hear this:
The 4 is arguably the best handling glider ever made with good performance. The 3/3a is perhaps an under rated value in the market. In strong conditions the 3/3a will go faster, otherwise the performance difference isn't worth chasing. Consider the trailer condition, aircraft condition and location in your interest level. The 3 has heavier wings, the 3a had slightly lower performance than the 3. Flaps on a first glider might be an unnecessary burden depending on your experience and skill level. If taken care of the finishes last 15-20 years it seems. Sanding and polishing will extend the life but many of the gliders from the 80's on are hurting right now. A refinish costs about as much as these airframes and there are only a handful of shops in the US that know what they are doing.
I say buy the nicest thing in your price range and find a reason to love it.. I never wanted an ASW-24, but guess what I'm flying these days?
Good luck and enjoy the hunt!
-Doug
Old August 24th 19, 05:32 AM posted to rec.aviation.soaring
NMD
Thanks Doug!
Yes there is a lot of info on both LS3 and LS4 but I can find very little comparing the two directly.
Will definitely be looking for a ship with a good finish, or refinish. Hence the question about paint life span. Several of the gliders currently listed are advertising paint jobs from the 90’s.
Who are the trusted refinishing shops in the US?
Appreciate the info, Jason
Old August 24th 19, 04:42 PM posted to rec.aviation.soaring
Papa3[_2_]
As already mentioned, they are significantly different gliders. The original 3 has full-span flaperons and very heavy wings for a 15M glider. On the plus side, it has automatic control hookups for the wings, so no fiddling around in the dark with hotelier connections. Once assembled, it's a very nice flying ship with no vices and all the usual performance benefits of flaps (for high speed flight and landings). We're actually restoring our club LS3 right now and are looking forward to many more years of happy soaring with it.
The LS4 (I owned one for 5 years) is really the perfect first glass ship in most regards. One less thing to play with (no flap handle) but very good landing behavior thanks to extremely effective divebrakes. Manual connections for spoilers and divebrakes require a little more care in assembly, but no more than most other ships of that vintage.
They share many mechanicals including the flimsy LS canopy attachment, captive thumb-wheel stabilizer attachment, many cockpit layout features, etc. The landing gear on both is not as robust as Schleicher designs and the wheel brake is only fair to adequate (if you take care of it). Some people do not like the heel brakes on the LS4 but I actually loved that design as your hands were free to deal with the stick and divebrakes and you could keep full divebrakes while on the ground roll without using the wheel brake (or vice-versa).
Assuming you have some time in a glass two-seater and good briefing, you should have no problem with either. So, it comes down to finding the best on in your area in terms of finish condition (priority 1) trailer condition (priority 2) and instruments (priority 3).
Feel free to pm me directly if you want any other details about either ship; I think I have both flight and maintenance manuals for both around somewhere.
Also, there is a Yahoo group for LS Gliders (google it... hah).
Erik Mann (P3)
Old August 24th 19, 05:43 PM posted to rec.aviation.soaring
Papa3[_2_]
They share many mechanicals including the flimsy LS canopy attachment, captive thumb-wheel stabilizer attachment, many cockpit layout features, etc.. The landing gear on both is not as robust as Schleicher designs and the wheel brake is only fair to adequate (if you take care of it). Some people do not like the heel brakes on the LS4 but I actually loved that design as your hands were free to deal with the stick and divebrakes and you could keep full divebrakes while on the ground roll without using the wheel brake (or vice-versa).
Erik Mann (P3)
https://groups.yahoo.com/neo/groups/LS-gliders/info
Old August 24th 19, 08:49 PM posted to rec.aviation.soaring
Chris Behm
Erik Mann (P3)
What are the differences between LS4 and LS4a?
Thanks!
Old August 24th 19, 09:19 PM posted to rec.aviation.soaring
Chris Behm
Erik Mann (P3)
Thanks!
I found my own answer, thanks Wikipedia.... 4a has beefed up LG for increased water ballast capacity over the LS4. So, it would seem to be something worth seeking?
Old August 24th 19, 11:02 PM posted to rec.aviation.soaring
Papa3[_2_]
Meh. Depends on where you fly, but I suspect its pretty rare to fly an LS4 at max gross nowadays. In the US at least, club and sports class are dry, so it would really only matter for personal record flights.
Differences in O-540 models Charles Talleyrand Piloting 4 August 4th 08 02:04 AM
DG Differences... noel.wade Soaring 39 April 22nd 08 06:42 AM
Engine Differences Withheld By Request Piloting 3 September 6th 05 04:10 PM
Rep vs. Dem Differences Jim Weir Piloting 212 September 8th 04 04:02 PM
ASW 20, ASW 20B, ASW 20C DIFFERENCES Ventus B Soaring 8 July 18th 04 10:28 AM
