sustaining (turbo) gliders
Old February 28th 05, 09:11 PM
Pilot626
Default sustaining (turbo) gliders
When a glider uses sustaining engine instead of selflanching, does it
mean that I would not gain any attitude if I started the engine during
a flight?
Old February 28th 05, 10:17 PM
5Z
It means the engine does not provide enough thrust to get the glider
from 0 to a couple hunderd feet AGL. It may be possible to launch
given a low enough airport elevation and a long enough runway, but it
may not be safe.
-Tom
Old March 1st 05, 12:58 AM
Mal.com
1 knot to 2 knots maximum lift ASW 28 18 E
http://www.mals.net see links
"5Z" wrote in message
may not be safe.
-Tom
Old March 1st 05, 02:14 AM
Bob Gibbons
The Ventus turbo provides about 250 ft/min climb rate at 1000ft ASL,
decreasing with altitude up to perhaps 10000-12000ft ASL where zero
climb (pure sustaining) is possible.
Bob
Ventus cT
a flight?
Old March 1st 05, 03:30 AM
bumper
My ASH26E, a self-launch glider, has a 50 horse power Wankel engine. This
engine remains stationary in the fuselage and only the prop and radiator
come up into the airstream on the pylon. As a self-launch, it obviously has
enough power to get off the ground in a short distance and climb fairly
quickly, even in high and hot conditions. It also has an electric starter to
facilitate both ground and air starting.
Many "turbo" or sustainer ships don't trouble themselves with such add-ons
as electric start. Rather they raise the engine and use airflow to turn the
prop for starting. As mentioned in another post, engine power will be enough
for a slow climb, but not enough for self-launch under normal conditions.
all the best,
bumper
"Pilot626" wrote in message
a flight?
Hanger and gliders hit by storm. [email protected] Soaring 6 February 1st 05 01:44 AM
Production rates? Ed Byars Soaring 38 November 24th 04 04:13 PM
Anti collision systems for gliders Simon Waddell Soaring 2 September 21st 04 08:52 AM
Do you like gliders but hate FAA checkrides? Bruce Hoult Soaring 8 August 13th 04 05:14 PM
Underwater Gliders Burt Compton Soaring 6 November 25th 03 04:43 AM
