https://en.wikipedia.org/wiki/McDonn...KC-10_Extender
The McDonnell Douglas KC-10 Extender is an aerial refueling tanker aircraft operated by the United States Air Force (USAF). A military version of the three-engined DC-10 airliner, the KC-10 was developed from the Advanced Tanker Cargo Aircraft Program. It incorporates military-specific equipment for its primary roles of transport and aerial refueling. It was developed to supplement the KC-135 Stratotanker following experiences in Southeast Asia and the Middle East. The KC-10 was the second McDonnell Douglas transport aircraft to be selected by the Air Force following the C-9. A total of 60 KC-10s were produced for the USAF. The Royal Netherlands Air Force operates two similar tankers designated KDC-10 that were converted from DC-10s. The KC-10 plays a key role in the mobilization of US military assets, taking part in overseas operations far from home. These aircraft performed airlift and aerial refueling during the 1986 bombing of Libya (Operation Eldorado Canyon), the 1990–91 Gulf War with Iraq (Operations Desert Shield and Desert Storm), the NATO bombing of Yugoslavia (Operation Allied Force), War in Afghanistan (Operations Enduring Freedom), and Iraq War (Operations Iraqi Freedom and New Dawn). The KC-10 is expected to serve until 2043. The KC-10 Extender first flew on 12 July 1980, but it was not until October the same year that the first aerial refuel sortie was performed. The design for the KC-10 involved modifications from the DC-10-30CF design. Unnecessary airline features were replaced by an improved cargo-handling system and military avionics. Meanwhile, the KC-10 retains 88% commonality with its commercial counterparts, giving it greater access to the worldwide commercial support system. Other changes from the DC-10-30CF include the removal of most windows and lower cargo doors. Early aircraft featured a distinctive light gray, white and blue paint scheme, but a gray-green camouflage scheme was used on later tankers. The paint scheme was switched to a medium gray color by the late 1990s. The most notable changes were the addition of the McDonnell Douglas Advanced Aerial Refueling Boom (AARB) and additional fuel tanks located in the baggage compartments below the main deck. The extra tanks increase the KC-10's fuel capacity to 356,000 lb (161,478 kg), nearly doubling the KC-135's capacity. The KC-10 has both a centerline refueling boom—unique in that it sports a control surface system at its aft end that differs from the V-tail design used on previous tankers—and a drogue-and-hose system on the starboard side of the rear fuselage. The KC-10 boom operator is located in the rear of the aircraft with a wide window for monitoring refueling. The operator controls refueling operations through a digital fly-by wire system. Unlike the KC-135, the KC-10's hose-and-drogue system allows refueling of Navy, Marine Corps, and most allied aircraft, all in one mission. The final twenty KC-10s produced included wing-mounted pods for added refueling locations. The KC-10 can also carry a complement of 75 personnel with 146,000 lb (66,225 kg) of cargo, or 170,000 lb (77,110 kg) in an all-cargo configuration. The KC-10 has a side cargo door for loading and unloading cargo. Handling equipment is required to raise and lower loads to the cargo opening. It can carry cargo and serve as a tanker on overseas missions. Role Aerial refueling tanker, multi-role aircraft National origin United States Manufacturer McDonnell Douglas First flight 12 July 1980 Introduction March 1981 Status In service Primary users United States Air Force Royal Netherlands Air Force Produced KC-10: 1979–1987 Number built KC-10: 60; KDC-10: 2 Unit cost KC-10: US$88.4 million (FY1998) Developed from McDonnell Douglas DC-10 The first KC-10 was delivered to the Air Force's Strategic Air Command (SAC) in March 1981 at Barksdale AFB; the 60th and final KC-10 arrived on 29 November 1988. The KC-10s served with SAC until 1992, when they were reassigned to the newly established Air Mobility Command. In the aerial refueling role, the KC-10s have been operated largely in the strategic refueling of large number of tactical aircraft on ferry flights and the refueling of other strategic transport aircraft. Conversely, the KC-135 fleet has operated largely in the in-theater tactical role. There are 59 KC-10 Extenders in service with the USAF as of 2010. The USAF's KC-10s are stationed primarily at Travis AFB, California, and Joint Base McGuire-Dix-Lakehurst formerly known as McGuire AFB, New Jersey. The Air Force considered retiring its fleet of KC-10 tankers in response to sequestration budget cuts as part of the service's FY 2015 budget. A "vertical chop" to divest all KC-10s was suggested because there are fewer KC-10s than KC-135s, having three different tanker models in service (after the introduction of the KC-46) would be costly, and a "horizontal cut" across the refueling fleets would achieve small efficiencies. Some believed retiring the KC-10 would not benefit the Air Force, given that it is equipped with both boom and hose-and-drogue refueling systems and the fleet's relatively young age. At first, officials claimed that the initial focus on retiring the KC-10 in September 2013 was a "trial balloon" to call attention to Air Force operating cost issues; as of early 2013, the KC-10 had a per hour flying cost of $21,170 and a mission capable rate of 87 percent. A FY 2015 budget plan did not include cuts to the KC-10. Specifications (KC-10A) General characteristics Crew: 4 (Aircraft Commander, copilot, flight engineer, and boom operator) Length: 181 ft 7 in (55.35 m) Wingspan: 165 ft 4.5 in (50.41 m) Height: 58 ft 1 in (17.70 m) Wing area: 3,958 ft² (367.71 m²) Empty weight: 241,027 lb (109,328 kg) Loaded weight: 593,000 lb (268,980 kg) Max. takeoff weight: 590,000 lb (267,620 kg) Maximum fuel capacity: 356,000 lb (161,480 kg) Powerplant: 3 × F103/General Electric CF6-50C2 turbofans, 52,500 lbf (236 kN) each Performance Maximum speed: 538 knots/0.89 mach (619 mph, 996 km/h) Range: 4,400 mi (7,080 km) Ferry range: 11,500 mi (18,507 km) Service ceiling: 42,000 ft (12,800 m) Rate of climb: 6,870 ft/min (2094 m/min., 34.9 m/s) * |
McDonnell Douglas T-45 Goshawk pics 2 [2/8] - mcdonnell-douglas-boeing-t45-goshawk_12.jpg (1/1) | Miloch | Aviation Photos | 0 | April 20th 17 02:56 PM |
McDonnell Douglas T-45 Goshawk pics 1 [11/12] - mcdonnell-douglas-boeing-t45-goshawk_9.jpg (1/1) | Miloch | Aviation Photos | 0 | April 20th 17 02:54 PM |
McDonnell Douglas T-45 Goshawk pics 1 [10/12] - mcdonnell-douglas-boeing-t45-goshawk_8.jpg (1/1) | Miloch | Aviation Photos | 0 | April 20th 17 02:54 PM |
McDonnell Douglas T-45 Goshawk pics 1 [08/12] - mcdonnell-douglas-boeing-t45-goshawk_6.jpg (1/1) | Miloch | Aviation Photos | 0 | April 20th 17 02:54 PM |
McDonnell Douglas T-45 Goshawk pics 1 [06/12] - mcdonnell-douglas-boeing-t45-goshawk_4.jpg (1/1) | Miloch | Aviation Photos | 0 | April 20th 17 02:54 PM |
