Sweden says it built a Russian fighter jet killer — and stealth is totally irrelevant - The Gripen E series fully armed.jpg ...
Old February 9th 19, 07:46 PM posted to alt.binaries.pictures.aviation
Miloch
Default Sweden says it built a Russian fighter jet killer — and stealth is totally irrelevant - The Gripen E series fully armed.jpg ...
https://www.businessinsider.com/swed...elevant-2019-2
Sweden's air force says its Gripen E fighter jets are designed to kill Russia's
fearsome Sukhoi fighter jets, and that they have a "black belt" in that type of
combat.
The Gripen E can't carry the most weapons and has no real stealth. And it isn't
the longest-range, fastest, or even cheapest jet. But it has a massive and
respected electronic-warfare capability.
The Gripen E is Sweden's cheap solution to killing Russia's fighter jets and
surface-to-air missiles, and Russia probably can't do much about it.
The commander of Sweden's air force, Mats Helgesson, recently made the bold
statement that his country's Saab Gripen E fighter could beat Russia's
formidable fleet of Sukhoi jets with none of the expensive stealth technology
the US relies on.
"Gripen, especially the E-model, is designed to kill Sukhois. There we have a
black belt," Helgesson told Yle at a presentation in Finland, where Sweden is
trying to export the jets.
Russia's Sukhoi fighters have achieved a kind of legendary status for their
ability to out-maneuver US fighter jets in dogfights and pull off dangerous and
aggressive stunts in the air, but Gripen may have cracked the code.
The Gripen can't carry the most weapons and has no real stealth. And it isn't
the longest-range, the fastest, or even the cheapest jet. But it has a singular
focus that makes it a nightmare for Russia's fighter jets.
Justin Bronk, an aerial-combat expert at the Royal United Services Institute,
told Business Insider that like the A-10 Warthog was built around a massive
cannon, the Gripen was built around electronic warfare.
Virtually all modern jets conduct some degree of electronic warfare, but the
Gripen E stands above the rest, according to Bronk.
Gripen pilots don't like to show their cards by demonstrating the full power of
the jet's jamming in training. But the one time they did, it completely reversed
the course of the mock battle in training, Bronk said.
"Several years ago the Gripen pilots got tired of being made fun of by German
Typhoon pilots and came to play with their wartime electronic warfare and gave
them a hell of a hard time," Bronk said. One of the Gripens was "reportedly able
to appear on the left wing of a Typhoon without being detected" by using its
"extremely respected" jamming ability, Bronk said.
"It would be fair to assume the Gripen is one of the most capable electronic
warfighters out there," he said, adding that the Gripens that baffled the
Typhoons were of the C/D series, which have much less powerful
electronic-warfare capabilities than the E series Gripens that Helgesson
described.
To defeat Russia's fearsome fighters and surface-to-air missiles, the US has
largely turned to stealth aircraft. Stealth costs a fortune and must be built
into the shape of the plane.
If Russia somehow cracks the code of detecting stealth-shaped fighters, the US's
F-35, the most expensive weapons system in history, is cooked.
But Saab took a different, and cheaper, approach to combating Russia's fighters
and missiles by focusing on electronic attack, which gives them an advantage
over stealth because they can evolve the software without a ground-up rebuild,
according to Bronk.
Saab plans to update the software on the Gripen E every two years, giving it
more flexibility to meet evolving challenges, according to Bronk.
But Bronk noted one issue with electronic warfare.
"The problem with basing a survival strategy around an electronic warfare suite
is you don't really know if it's going to work," he said. "Even if it does, it's
going to be a constant battle between your adversary and you" to get the edge on
the enemy fighters as wave forms and methods of attack continuously change.
However, Sweden benefits from a Russian focus on US fighters. "Sweden is too
small really to optimize your counter-electronic warfare capabilities against,"
Bronk said.
If war broke out between Russia and the West, Russia would likely try hardest to
push back on US electronic warfare, rather than against Sweden's Gripen Es, of
which there would be only a few dozen.
The whole concept of the Gripen E is to "operate in Swedish territory, take
advantage of all sorts of uneven terrain under cover of friendly surface-to-air
missiles with a superb EW suite which should in theory keep it safe from the
majority of Russian missiles and air to air threats," Bronk said.
Additionally, the Gripen E can fire almost any missile made in the US or Europe.
"If you couple a very effective radar with excellent EW and a Meteor, the most
effective longest range air-to-air missile which is resistant against [Russia's]
jammers ... There's no reason not to assume it wouldn't be pretty damn
effective," Bronk said. "If you're a flanker pilot, it's probably a very scary
thing to face."
Name:	The Gripen E series fully armed.jpg
ID:	112768  Click image for larger version
Name:	Sweden's Saab Gripen in flight.jpg
China's J-20 Stealth Fighter Stuns By Brandishing Full Load Of Missiles At Zhuhai Air Show - China's J-20 Stealth Fighter 2.jpg ... Miloch Aviation Photos 0 November 12th 18 02:54 AM
High-Quality Shots Of Unpainted Chinese J-20 Stealth Fighter Offer New Capability Insights [5/5] - Chinese J-20 Stealth Fighter.jpg (1/1) Miloch Aviation Photos 0 August 1st 18 02:59 PM
High-Quality Shots Of Unpainted Chinese J-20 Stealth Fighter Offer New Capability Insights [4/5] - Chinese J-20 Stealth Fighter 5.jpg (1/1) Miloch Aviation Photos 0 August 1st 18 02:59 PM
High-Quality Shots Of Unpainted Chinese J-20 Stealth Fighter Offer New Capability Insights [3/5] - Chinese J-20 Stealth Fighter 4.jpg (1/1) Miloch Aviation Photos 0 August 1st 18 02:59 PM
High-Quality Shots Of Unpainted Chinese J-20 Stealth Fighter Offer New Capability Insights [2/5] - Chinese J-20 Stealth Fighter 3.jpg (1/1) Miloch Aviation Photos 0 August 1st 18 02:59 PM
