Caution - InterAv "Spike Guard" Capacitor
Old July 1st 03, 06:47 AM
Robert Bonomi
Default Caution - InterAv "Spike Guard" Capacitor
Jim Weir wrote:
Ah, no sir, sorry. You may want to google how an electrolytic capacitor works.
I got my initial commercial 1st class broadcast engineer license in 1970.
I've got a fair library on the bookshelves.
But thanks the advice.
From Meade, "Foundations of Electronics", from which I've been teaching freshman
engineering students for a few years now...
"The external aluminum can, or housing, is typically the negative plate (or
electrode). The positive electrode external contact is generally aluminum foil
immersed or in contact with an electrolyte of ammonium borate (or equivalent).
To create the dielectric, a dc current is passed through the capacitor. This
causes a very thin aluminum oxide film (about 10 microcm thick) to form on the
foil surface. THIS THIN OXIDE FILM IS THE DIELECTRIC."
Emphasis mine. Meade 1. Bonomi 0.
I fully understand the difference between electrolyte and dielectric.
I note that the dielectric was _not_ the subject under discussion.
Meade identifies two plates in the electrolytic capacitor -- the first
being (usually) the can; the second being the foil. I do maintain that the
electrolyte is 'between' those two plates.
Furthermore, I've used electrolytic capacitors that were constructed
with two foil plates, which did *not* use the 'can' as part of the circuit.
You get significantly higher capacitance values that way -- in the same
_physical_ space --by minimizing the 'distance' of the ion transference.
If one _was_ discussing the characteristics of the dielectric, it would be
appropriate to call it "dielectric materialism". groan Which I will
stay away from, other than to note that if the electrolyte is _not_ present
between the plates of the capacitor, then the dielectric does _not_ form
when current is supplied. And all you have is the equivalent of an 'air gap'
type with a surface area approximating that of the 'can', in the case where
the can is used as the negative plate. In the case of a 'dual foil' plate
design, the usual result of loss of electrolyte is an "arc-over", aka short,
between the plates. A "catastrophic" failure of a near-explosive proportions..
bonomi@c-ns. (Robert Bonomi)
-The electrolyte in a capacitor, just like in a battery, is what is _between_
-the plates.
http://www.rst-engr.com
Old July 1st 03, 02:49 PM
Model Flyer
"Robert Bonomi" bonomi@c-ns. wrote in message
foil' plate
aka short,
proportions..
Had a nice failure with a 150mf 400 volt eletrolitic, the top blew
out as if you fired a .22 bullet through it. This was caused by a
power surge caused by the supply company. Apart from the cap in the
monitors psu, it also blew, the psu of a printer, the computer psu,
the microwave, cooker and Hi-Fi system. A few other household
electrical items were damaged as well.:-)
Cheers,
Jonathan Lowe
modelflyer at antispam dot net
Antispam trap in place
is _between_
-the plates.
Old July 1st 03, 04:47 PM
Jim Weir
-I got my initial commercial 1st class broadcast engineer license in 1970.
-I've got a fair library on the bookshelves.
If you want to play old-fart one-upmanship, my 1st phone was in 1959 on my 16th
birthday. I believe that 16 was the limit back in 'dem golden oldie days. I
did third, second, and first all in one sitting. That, of course, was to
supplement my ham ticket which I had obtained in '57.
And I'm not about to play "mine is bigger than yours" only to state that I've
got a few books on my shelves, too. Two of which I haven't even colored yet
Nor am I about to go on and on about a simple question since the resolution is
that even shorted, this device isn't going to fail catastrophically.
In practice, a shorted electrolytic (save physical "mash" damage) is about as
rare as a shorted resistor. RST's gone through, what, half a million of them in
30 years without a shorted one yet. A couple of dozen opens, but no shorts.
That seems to be the industry trend.
Old July 2nd 03, 02:10 AM
Robert Bonomi
16 was still the minimum in '70. I was about 3 mo short of turning 17.
(They were administered locally only once every six months.) I took 'em all
in one sitting, too.
I won't mention my complete collection of Dr. Seuss, either.
Other people have direct experience to the contrary.
I'll agree with that -- while noting that wire-wound resistors _can_ short.
I've got a far smaller 'sample population', probably only in the low-middle
4 figures. I've seen _one_ that was an 'open' -- factory defect; _no_ innards
whatsoever. I've also had *four* explode due to short. Admittedly, I don't
think they were _less_ than 30 years old.
Old July 3rd 03, 04:25 AM
Jim Weir
Roughly...zero.
Ernest Christley
-Don't know how much this applies, but I worked at a custom electronics
-manufacturer.
Old July 4th 03, 04:10 AM
MikeremlaP
Okay guys, I cut the cap open.
See foto at
http://www.fotolog.net/palmer_mp/
No foil that I can see. In fact, I'm not sure how this thing works. I thought
the idea was to create maximum surface area.
I probably should have buzzed the negative terminal to the can to see if
connected. (Can do that tomorrow).
Black stuff has a strong order to it...
In any event, it seems that, with vertical mounting, lugs down, either
component could rattle its way to short the inputs. I'm surprised it didn't
happen.
Mike Palmer
Excellence in Ergonomics, but apparently obsolete in Electrical Engineering.
Old July 4th 03, 03:30 PM
James M. Knox
"Peter Gottlieb" wrote in
t:
Ooooh, that melted down big time. Looks like it arced in there.
I think the one that looks like a pestle, that can still be unwrapped
if you try.
This unit may have consisted of three paralleled rolls, but, just
guessing without closer examination.
Yeah, if you don't mind getting your hands dirty (again) try Peter's theory
to see if you can unroll some of the insides.
The capacity goes up linearly as a function of the surface area, but as the
square (if I recall) of the separation of the conductors. No way in heck
you are going to get 6000 uF out of one rod in the middle, with a big gap
to the outer can.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old July 4th 03, 04:43 PM
Jim Weir
In the FPS system,
C = 0.224 (KA/d)(n-1)
K= dielectric constant
A= area of one side of one plate in square inches
d= separation of plate surfaces in inches
n= number of plates
No square term, sorry.
"James M. Knox"
-The capacity goes up linearly as a function of the surface area, but as the
-square (if I recall) of the separation of the conductors.
Old July 4th 03, 06:13 PM
Peter Gottlieb
The 1/d term is what gets the high values for capacitance when you have a
small "d," as in microinches.
"Jim Weir" wrote in message
In the FPS system,
n= number of plates
"James M. Knox"
Old July 5th 03, 06:06 AM
MikeremlaP
Hi guys:
Probably getting off topic a bit, although my original concern was safety of
flight, and things shorting out. Are we agreed that this type of capacitor
construction is too prone to vibration for aircraft use and that it has a bad
failure mode?
I cut into the guts of the cap - I'm still clueless. Guess some reading is in
order on my part. If someone wants to educate me, either on or off line...
The 2nd cut photo is he
Mike Palmer
