Looking for 57 mm instruments
Old September 21st 19, 03:43 PM posted to rec.aviation.soaring
Default Looking for 57 mm instruments
I am upgrading my panel, and the big screen TV takes up a lot of room. Looking for 57 mm Variometer and Airspeed Indicator. Preferably in FPM and Knots.
Old September 21st 19, 03:48 PM posted to rec.aviation.soaring
Mike N.
I have an excellent condition LXNav S7 / V7 I am selling.
Excellent condition. I can take pictures of it working in my glider.
I just purchased an S80 because I wanted an 80mm vario.
I was thinking 700 for price.
Contact me by email at mikelleen AT gm..l.com
Yes address above is disguised plug gmail
Old September 21st 19, 04:00 PM posted to rec.aviation.soaring
I should have specified: Mechanical Vario and ASI wanted. The new panel will have an LXNAV V8 and 9000, along with a Butterfly display. I want mechanical vario, ASI and altimeter as backup in case of electrical failure. (Like too much smoke in the cockpit.)
Old September 21st 19, 06:43 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Don't turn down a 57mm Borgelt B.40 if offered one: It normally runs off
the standard 12v panel power but can have a 9v PP3 battery strapped on
the back, which will run it for (IIRC) 12 hours if the main batteries
fail. Its power switch lets you select external 12v or 9v backup.
I use one as my backup vario and wouldn't willingly swap it for anything
else except, maybe, a B.400.
Martin | martin at
Gregorie | gregorie dot org
Old September 21st 19, 07:53 PM posted to rec.aviation.soaring
Ross[_3_]
I have an ASI in knots here
I will be in Alabama in a week and can bring it with me if you like
Old September 22nd 19, 01:33 AM posted to rec.aviation.soaring
Price? Manufacturer? Range? Markings?
Old October 10th 19, 02:29 PM posted to rec.aviation.soaring
Still looking for a 57 mm Winter or Sage variometer, preferably calibrated in knots or FPM. Not interested in Borgelt or other electric units.
Old October 12th 19, 01:44 PM posted to rec.aviation.soaring
Mark- I don't read RAS very often so just saw this. If you'll check the right storage cabinet in my hangar, upper shelf on right- See if that Winter will work for you. I thought you had a 57mm Sage (?)
Gary Osoba
Old November 7th 20, 02:11 AM posted to rec.aviation.soaring
Tony[_7_]
Gary Osoba
Gary, is that 57mm Winter vario still sitting there?
Old November 7th 20, 02:18 AM posted to rec.aviation.soaring
Tony[_7_]
Gary Osoba
Dear Gary: still have 57mm Winter?
FS: instruments [email protected] Soaring 1 June 30th 08 06:04 AM
instruments [email protected] Soaring 9 August 3rd 07 10:56 PM
Instruments Steve Leonard Soaring 2 August 3rd 07 04:49 AM
How many instruments can I use for VFR? Mxsmanic Piloting 106 November 7th 06 02:56 AM
Instruments Kevin Berlyn Home Built 6 June 10th 05 02:11 AM
