Duo Discus wing root mod
Old September 25th 19, 03:59 AM posted to rec.aviation.soaring
JS[_5_]
Default Duo Discus wing root mod
Does anyone have a wing root mod for the Duo?
That sharp 90 degree junction on the underside of the wing is right out of the 1970s.
Contacted the usual suspects:
Streifeneder.
US S-H rep.
Lindner.
....With no luck.
Where's Rick Wagner when you need him?
Thanks!
Old September 25th 19, 09:55 AM posted to rec.aviation.soaring
krasw
Streifeneder.
US S-H rep.
Lindner.
...With no luck.
Thanks!
I can only imagine the conversation Schempp has had:
Young engineer: "All our competitors have hi-tech CFD wing-fuselage junctions, ours so prehistoric you cannot even seal it with tape. Would it be time to do something about it?"
Tilo: "Nein"
Old September 25th 19, 01:36 PM posted to rec.aviation.soaring
Streifeneder.
US S-H rep.
Lindner.
...With no luck.
Thanks!
Probably not all that critical on the high pressure side of the wing.
One could make some simple fillets and tape them on. Tuft the area and take some video with and without. This would show if worth doing any more. My guess would be not.
FWIW
UH
Old September 29th 19, 12:48 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Better yet, install 1/4" foam weather stripping tape around the entire mating surface on the fuselage and forget the tape. Works great.
KS
Streifeneder.
US S-H rep.
Lindner.
...With no luck.
Thanks!
Old October 2nd 19, 06:42 PM posted to rec.aviation.soaring
Piet Barber
Agree. Works great!
"You don't tape the wing roots on your Duo?!"
"No, I can't afford to both fly a Duo Discus *AND* tape the wing roots each time I fly" /s
Old October 2nd 19, 07:37 PM posted to rec.aviation.soaring
JS[_5_]
Thanks, I'll give the foam strip a try. Had been considering it on the flat part of the fuselage (mid-chord bottom surface) for a while.
At least we won't have to argue with the tape.
K8 wing root depth Mike Dowling Soaring 1 July 3rd 14 11:30 PM
Wing Root Fairing Bob Noel Owning 8 June 22nd 06 01:24 AM
Ventus A and B Wing Root Fairings [email protected] Soaring 17 June 24th 05 02:13 AM
Wing root fairings D.A.L Soaring 10 October 29th 03 11:36 AM
wing root strakes (not canard A/C) Wallace Berry Home Built 0 October 2nd 03 08:47 PM
