https://en.wikipedia.org/wiki/Hughes_XH-17
The Hughes XH-17 "Flying Crane" was the first helicopter project for the helicopter division of Hughes Aircraft Company. The XH-17, which had a two-bladed main rotor system with a diameter of 134 feet (41 m), still holds the world record for flying with the largest rotor system. It was capable of flying at a gross weight of more than 50,000 pounds (23,000 kg), but proved too inefficient and cumbersome to be mass-produced beyond the prototype unit. Role Helicopter Manufacturer Hughes Helicopters First flight 23 October 1952 Retired December 1955 Status Scrapped Number built 1 The XH-17 was a heavy-lift rotorcraft that was designed to lift loads in excess of 15 metric tons. To speed construction, parts of the XH-17 were scavenged from other aircraft. The front wheels came from a North American B-25 Mitchell and the rear wheels from a Douglas C-54 Skymaster. The fuel tank was a bomb bay-mounted unit from a Boeing B-29 Superfortress. The cockpit was from a Waco CG-15 military glider and the tail rotor from a Sikorsky H-19 Chickasaw was used for yaw control. In the late 1940s, Hughes developed an interest in helicopters. In August 1947, helicopter manufacturer Kellett sold his design for the giant XH-17 Sky Crane to Hughes, who commissioned the development of the XH-17 Flying Crane research vehicle. In 1948, the XH-17 began to take shape. The giant helicopter was tested in Culver City, California over a three-year period beginning in 1952. The XH-17 flew in 1953 at a gross weight in excess of 50,000 pounds (23,000 kg). It still holds the record for flying with the world's largest rotor system. Only one unit was built, since the aircraft was too cumbersome and inefficient to warrant further development. The propulsion system was unusual. Two General Electric J35 turbojet engines were used, sending bleed air up through the rotor hub. The blades were hollow, and the hot compressed air traveled through the blades to tip jets where fuel was injected. In flight, the main rotor spun at a sedate 88 revolutions per minute, less than half the speed of typical helicopter rotors. Since the rotor was driven at the tips rather than the hub, little torque compensation was required, mostly due to friction in the main rotor bearing. Thus, the XH-17 had a very small tail rotor compared to its main rotor. This drive system was inefficient, limiting the test aircraft to a range of only 40 miles (64 km). The XH-28 was a derivative, with a maximum weight of 104,000 pounds (47,000 kg). Though a wooden mockup of the design was made, the program was canceled and none were built. Specifications General characteristics Crew: 3 (pilot, mechanic and in-flight test engineer) Length: 53 ft 3 in (16.25 m) Rotor diameter: 129 ft 11 in (39.62 m) Height: 30 ft 2 in (9.17 m) Empty weight: 28,563 lb (12,956 kg) Useful load: 10,284 lb (4,665 kg) Loaded weight: 31,270 lb (14,184 kg) Max. takeoff weight: 43,500 lb (19,731 kg) Powerplant: 2 × General Electric J35 turbojets Performance Maximum speed: 90 mph (145 km/h) Cruise speed: 85 mph (137 km/h) Range: 40 mi (64 km) Service ceiling: 13,100 ft (3,995 m) Rate of climb: 1650 ft/min (8.4 m/s) Disc loading: 2.34 lb/ft² (11.5 kg/m²) * |
Hughes XF-11 pics [8/8] - Hughes-XF-11-Howard-Hughes-First-Prototype2.jpg (1/1) | Miloch | Aviation Photos | 0 | October 25th 18 02:46 PM |
Hughes TH-55 Osage pics 1 [06/12] - Hughes-TH-55_Osage cn 111-0029 AS 05-06-10 (1/1) | Miloch | Aviation Photos | 3 | April 26th 17 03:33 PM |
Hughes TH-55 Osage pics 1 [09/12] - IMG_7627-67-16879-Hughes-TH-55A-269C-Osage-US-Army-Russell-Military-Museum.jpg (1/1) | Miloch | Aviation Photos | 0 | April 26th 17 03:12 PM |
Hughes TH-55 Osage pics 1 [07/12] - Hughes-TH-55_Osage.jpg (1/1) | Miloch | Aviation Photos | 0 | April 26th 17 03:12 PM |
Hughes TH-55 Osage pics 1 [05/12] - Hughes-TH-55_Osage BI21306.jpg (1/1) | Miloch | Aviation Photos | 0 | April 26th 17 03:12 PM |
