Pawnee TOST Hook Installation FAA Paperwork
Old October 31st 19, 04:03 PM posted to rec.aviation.soaring
Default Pawnee TOST Hook Installation FAA Paperwork
We recently purchased a Pawnee that was a sprayer. In the process of changing the airworthiness certificate from Restricted Aerial Spraying to Restricted Towing. The DAR is looking for either an STC or 337 Field Approval paperwork for the TOST hook. The EASA Form 1 paperwork will not suffice. Does anyone have this paperwork? Please contact me ASAP.
Tim Hanke
518-365-7726 phone/ text
e-mail: tim AT adirondacksoaring.com
Old October 31st 19, 11:02 PM posted to rec.aviation.soaring
Bob Youngblood
Tim Hanke
There is NO STC! easy to get certified, 43-13-2A-B page 73-75,tells how to do it and get your mechanic to do a 337 and you are done with it. Bob
Old November 1st 19, 04:50 AM posted to rec.aviation.soaring
Frank Whiteley
Tim Hanke
One restricted category Pawnee 260 TOST 337 done here in Colorado was not approved by the Denver FAA Flight Standards Inspector. The tow plane was ferried to Wichita for approval. That may have been just before AC 43-13-2B was published. Presumably Albany will be accommodating.
Frank
Old November 1st 19, 11:10 AM posted to rec.aviation.soaring
Thanks Bob! I think AC 43-13-2B is what I needed.
Tim Hanke
Old November 8th 19, 03:06 PM posted to rec.aviation.soaring
Charles Longley
Out of curiosity why didn’t you move the Pawnee to a standard airworthiness certificate?
Old November 8th 19, 04:33 PM posted to rec.aviation.soaring
What's wrong with staying restricted?
Old November 8th 19, 04:38 PM posted to rec.aviation.soaring
Moving to standard not necessary and something of a hassle
Old November 9th 19, 02:31 AM posted to rec.aviation.soaring
Charles Longley
It’s restricted?
Old November 9th 19, 09:08 AM posted to rec.aviation.soaring
Bob Youngblood
Keep the RESTRICTED category!!
Old November 9th 19, 01:55 PM posted to rec.aviation.soaring
Charles Longley
I guess the only real advantage of having a standard airworthiness certificate is you could do what you want with the airplane when you’re not towing. Take a restricted Pawnee into Johnson Creek and hang out with the Super Cub guys. FAA might take a dim view.
Looking to buy Tost hook [email protected] Soaring 2 March 4th 17 01:02 PM
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
needed!! drawings/data for Tost hook for Pawnee thing73 Soaring 3 November 13th 09 02:14 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
