GLIDING INTERNATIONAL -- RESEARCH
Old November 3rd 19, 08:04 AM posted to rec.aviation.soaring
Default GLIDING INTERNATIONAL -- RESEARCH
We at Gliding International have just completed a three months study on the accident sitution in regard to our sport. We have examined (in detail) the 96 reported accidents which show that our problematic area of soaring flight relates to the landing phase.
We took note of all accidents from 1/1/2019 to 31/08/2019 which indicates for sure (on the conservative side) that fatalities for the calendar year of 2019 will be 43. No organisation or sport should turn a blind eye to what is obviously a totally unacceptable situation.
We haven't got an answer to this problem but we are open to discussion and be a catalyst for change.
Also in our November issue is a report from Sebastian Kawa who has personally set out to explain his recent serious accident. An uphill landing into a very questionable landing zone with no options. He must be complimented for writing his report on the accident for our sport enthusiasts. He tells all how to avoid a repetition of the problem. Basically the accident emanated from the failure of his motor to start. He has quoted the number of experiences he has personally experienced with motor failures and has started a war on brands of motors that must be regarded as totally unreliable.
JOHN ROAKE
EDITOR
Old November 3rd 19, 12:23 PM posted to rec.aviation.soaring
Paul T[_4_]
study on
the=
detail)
th=
soaring
fl=
indicates
f=
year
of=
to
what=
discussion and
has
personal=
into
complimented
tells
emanat=
number of
exp=
started
unreliable.
JOHN ROAKE
EDITOR
One should never rely on the motor to start.........
Old November 3rd 19, 03:49 PM posted to rec.aviation.soaring
Dan Marotta
The engine's failure to start did not cause the accident.Â* The reliance
on the engine to start was one link in the accident chain.
study on
the=
detail)
th=
soaring
fl=
indicates
f=
year
of=
to
what=
discussion and
has
personal=
into
complimented
tells
emanat=
number of
exp=
started
unreliable.
JOHN ROAKE
EDITOR
Dan, 5J
Old November 3rd 19, 04:19 PM posted to rec.aviation.soaring
jfitch
study on
the=
detail)
th=
soaring
fl=
indicates
f=
year
of=
to
what=
discussion and
has
personal=
into
complimented
tells
emanat=
number of
exp=
started
unreliable.
JOHN ROAKE
EDITOR
Dan, 5J
From the Schleicher ASH26E manual: "The powerplant of a powered sailplane must not be regarded as life insurance, for instance when crossing unlandable areas. One must always be prepared for the possibility that the engine will fail to deliver the hoped for propulsion". This was a clear case of pilot error, the sailplane performed as expected.
Old November 3rd 19, 02:24 PM posted to rec.aviation.soaring
"No organisation or sport should turn a blind eye to what is obviously a totally unacceptable situation."
It is acceptable otherwise we wouldn't do it. If it is totally unacceptable we should have an immediate indefinite worldwide glider grounding. Be careful how you think and speak about these things.
Old November 3rd 19, 06:56 PM posted to rec.aviation.soaring
JOHN ROAKE
EDITOR
The accident did not emanate from the failure of the motor to start. The accident emanated from the fact that the pilot entered into a situation in which there was not a security field for landing within reach of the glider.
Old November 3rd 19, 07:26 PM posted to rec.aviation.soaring
Mike C
JOHN ROAKE
EDITOR
Old November 3rd 19, 07:58 PM posted to rec.aviation.soaring
Darryl Ramm
Also in our November issue is a report from Sebastian Kawa who has personally set out to explain his recent serious accident. An uphill landing into a very questionable landing zone with no options. He must be complimented for writing his report on the accident for our sport enthusiasts. He tells all how to avoid a repetition of the problem. Basically the accident emanated from the failure of his motor to start. He has quoted the number of experiences he has personally experienced with motor failures and has started a war on brands of motors that must be regarded as totally unreliable..
JOHN ROAKE
EDITOR
I thought that electric systems were very dependable.
So what?
Nobody is saying they are not. Even if you think a motorglider/sustainer engine will start reliably do you think it's sensible to assume it absolutely will and not have a landout option/plan B?
This is the most elementary basic safe operation of a motorglider 101 stuff..
Pretty stupid wording on "cause" used by Gliding International.
Old November 3rd 19, 08:16 PM posted to rec.aviation.soaring
Dave Nadler
No, you are flying a GLIDER.
**Plan A** must always be a safe land-out.
Plan B is in the event everything works as intended,
which certainly does not always happen...
Old November 3rd 19, 08:28 PM posted to rec.aviation.soaring
Mike C
JOHN ROAKE
EDITOR
So what?
Chuckle.
Never said I thought that. Never have been in a motor glider just thought that the electric system was very reliable, and am surprised to hear that they are not.
What has become of Gliding International? 2G Soaring 7 August 23rd 18 06:20 AM
Gliding International [email protected] Soaring 5 March 25th 16 09:33 AM
Gliding Research Assistance Kevin Christner Soaring 2 March 17th 13 09:13 PM
GLIDING INTERNATIONAL [email protected] Soaring 0 February 20th 09 10:46 PM
Gliding International john Soaring 0 May 4th 08 12:29 AM
