Phoebus Tow Release Needed
Old November 24th 19, 08:16 PM posted to rec.aviation.soaring
Bob Youngblood
Default Phoebus Tow Release Needed
Our club recently was gifted a late production Phoebus for our youth program to assist it rebuilding. The ship is like no Phoebus that you have ever seen! Without further detail all I will say is WOW! World class painter was commissioned to do the artwork on the tail.
What we need is some information on the tow release mechanism. The release is a Tost model 33192. This release is for winch towing, in as much as the ring will rotate back at the top of the tow allowing the release to automatically open. We would kike to change this to a locked ring collar model that will allow for aero tow only if possible. This may possibly be the only type available, I am not that cognizant of this release or model.
Does anyone out there know anything about this model or a replacement that would work. Thanks, Bob
Old November 24th 19, 08:29 PM posted to rec.aviation.soaring
Dan Marotta
Pictures?
Dan, 5J
Old November 24th 19, 09:59 PM posted to rec.aviation.soaring
Mike C
I owned a Phoebus C. There were no problem aero towing it. It is a type certified glider, so changing the type of tow hook may not be allowed and probably not recommended by Tost. Contacting Rudolph Lindner would probably be the best place for advice for the Phoebus.
http://www.ltb-lindner.com/home.104.html
Old November 24th 19, 10:42 PM posted to rec.aviation.soaring
Nick Gilbert[_2_]
Difficult to know exactly what the release in question looks like, but there is no problem aerotowing from both common styles of tost release. My DG100 has only a belly release with the back release function as you described. A bit of wheel brake on take up slack can stop the glider overrunning the rope and back releasing.
The type of belly release i'm referring to looks like this :
https://gliderstuff.com.au/product/t...dg-salto-sh72/
Nick.
Old November 25th 19, 04:07 PM posted to rec.aviation.soaring
Scott Williams[_2_]
Hey Bob,
I had a Phoebus C for a while, the belly release was a regular Tost E-85, but there was an AD/TN relocating the release from the gear to the belly. I believe the retractible gear location was determined to be too far aft for safe winching. Mine had a trim cover plate that allowed the moving ring to back release.
Good luck,
Scott
Old November 25th 19, 04:36 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Bob,
I think what you are seeing is the serial number of the release, not the model number. And as others have said, you do not want to change to a different type of release. Back then, I guess pilots were more interested in flying their planes, so a single tow hitch location worked for both air and ground launches.
Take a look at the pictures of the Tost releases on Wings and Wheels. Look through the papers on the plane. It s probably new enough that it doesn't fall under the "every X years" but falls under the number of actuations limitation.
I would encourage you to not go changing something that is not likely broken and does not need changing.
Just my two cents worth. Enjoy the plane. Oh, I have the Phoebus C that Scott Williams mentions in his note above. I need to get busy on that plane!
Steve Leonard
Old November 25th 19, 06:49 PM posted to rec.aviation.soaring
Bob Youngblood
On Monday, November 25, 2019 at 11:36:35 AM UTC-5, Steve Leonard wrote:
Bob,
Steve Leonard
Thanks to all, I have decided to send the unit back to TOST for their rebuild option. As Steve said, I am probably looking at the serial number. Sending it back is the best option, they offer a two week turn around. Yes, these young pirates of the club will certainly enjoy the ship. Bob
Old November 25th 19, 08:00 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Just curious, Bob. Is this N500BP? If so, I know that plane, and it is the one Mike C use to own.
Enjoy the plane!
Steve Leonard
Old November 25th 19, 08:54 PM posted to rec.aviation.soaring
Bob Youngblood
Enjoy the plane!
Steve Leonard
Steve, this plane came from Arizona and was owned by Tony C. Old number was N8364H, and we are in the process of getting a new number. The old number was reassigned to someone else. I will try to get some pics to you.
I just sent the hook to W&W, thy are going to identify and exchange. Thanks, Bob
Old November 25th 19, 10:17 PM posted to rec.aviation.soaring
Bob Youngblood
Enjoy the plane!
Steve Leonard
Oops, 8634H sorry for the mistake. Bob
How did you like the pics?
Tow release pulley needed for DG 100/200. Anyone have oldstock parts? PBA Soaring 1 August 11th 15 12:53 AM
Phoebus c and Mistral C ND Soaring 0 January 21st 15 03:54 PM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
WTB phoebus A or B rudder shkdriver Soaring 0 March 9th 12 03:46 AM
Phoebus B AFSax Soaring 2 August 18th 05 08:51 PM
