https://en.wikipedia.org/wiki/Vickers_Virginia
Work on the Virginia was started in 1920, with the aim of developing a replacement for the Vimy. Two prototypes were ordered on 13 January 1921 and another two prototypes were ordered in September 1922. The Virginia was similar to the Vimy, but notably had a lowered front gunner's pulpit to allow the pilot a greater field of view, 20 ft (6 m) greater wingspan, and a 9 ft (3 m) longer fuselage. The Virginia was powered by twin Napier Lion engines. The Virginia flew for the first time on 24 November 1922. At the Aircraft Experimental Establishment at RAF Martlesham Heath, the Virginia prototype underwent type trials. One of the first modifications was to replace the original two-bladed propellers with four-bladed propellers. An unusual set of "fighting top" turrets were added to the top wings, but these were later deleted from production aircraft. The Marks I–VI had straight wings, whereas the Mark VII introduced swept outer wings. Starting with the Mark III the Virginia mounted a rear fuselage gunner, who was moved into a tail turret in the Mark VII. The Mark X was introduced in late 1924 and featured a duralumin and steel structure covered in fabric, aluminium, and wood. A total of 124 Virginias were built, of which 50 were Mark X variants. Role Heavy night-bomber Manufacturer Vickers Limited First flight 24 November 1922 Introduction 1924 Retired 1941 Primary user Royal Air Force Number built 124 Developed from Vickers Vimy The first squadron of Mark I Virginias was formed in 1924. Despite mediocre performance, the aircraft served frontline units until 1938, when it was replaced by the newer Wellingtons, Hampdens and Whitleys. Newer designs such as the Fairey Hendon and Handley Page Heyford supplemented rather than replaced the Virginia. The final almost all-metal Virginia Mark X was the most numerous RAF bomber until the ascendance of the Heyford in 1934. After its technical obsolescence as a bomber it was used for photography and for parachute training, with jump platforms installed behind the engine nacelles. On 26 June 1940, a committee discussing the need for airborne cannon for use against invading tanks suggested equipping Virginias with the equally antiquated 37 mm (1.46 in) Coventry Ordnance Works gun. This was not acted on. In the 1930s, the Virginias were used in some of the first tests of midair refuelling, although they were never used in this role outside of tests. The Virginia was developed in parallel with the Vickers Victoria freighter, and the two aircraft had much in common, notably sharing the same wing design. The Virginias were highly accident prone, with 81 lost in this manner. Despite their obsolescence, Virginias continued to soldier on in support roles with the Parachute Test Flight at Henlow until December 1941. Specifications (Virginia X) General characteristics Crew: Four Length: 52 ft 3 in (15.93 m) Wingspan: 87 ft 8 in (26.72 m) Height: 18 ft 2 in (5.54 m) Wing area: 2,178 sq ft (202.3 m2) Empty weight: 9,650 lb (4,377 kg) Gross weight: 17,600 lb (7,983 kg) Powerplant: 2 × Napier Lion VB 12-cylinder water-cooled broad arrow engines, 580 hp (430 kW) each Performance Maximum speed: 108 mph (174 km/h; 94 kn) at 5,000 ft (1,500 m) Range: 985 mi (856 nmi; 1,585 km) Service ceiling: 13,800 ft (4,200 m) Time to altitude: 10 min to 5,000 ft (1,500 m) Armament Guns: 3 × .303 in (7.7 mm) Vickers machine guns Bombs: 3,000 lb (1,360 kg) of bombs * |
| Thread Tools | |
| Display Modes | |
| UK1 J7560 Vickers Virginia 1926-09 Manston GordonSwanboroughColl.jpg | Joseph Testagrose | Aviation Photos | 0 | November 13th 13 01:58 PM |
| UK1 J7710 Vickers Virginia.jpg | Joseph Testagrose | Aviation Photos | 0 | October 3rd 13 06:38 AM |
| UK1 K2674 Vickers Virginia.jpg | Joseph Testagrose | Aviation Photos | 0 | September 26th 13 01:50 PM |
| Britain Between the Wars, pt 7 - Vickers Virginia.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | January 26th 10 03:34 PM |
| Fly-ins in Northern Virginia? | Flyingmonk | Piloting | 8 | September 7th 05 08:57 PM |
