Looking for propeller Flange information
Old September 8th 04, 04:19 AM
Guy Deraspe
Default Looking for propeller Flange information
Is there a web site or a book on "Everything you want to know on
aircraft engine-propeller flange"?
I have done some searches on the web, but I always get to specific
propeller or engine model. They state Standard SAE #1, #2, ...
modified... Lycoming bolt pattern... Continental Bolt pattern ... which
would be equivalent to Aeronautical Standard AS127... but nothing in
general, which one to use for this or that application...
Any good reference?
SAE is selling their standard for about 50$, but I am sure I can find
the same information for much less
Guy Deraspe
Old September 8th 04, 10:30 AM
smjmitchell
I have SAE AS127D --- it is a grand total of 3 pages.
The following is a summary:
SAE #1 0.375, 4.375, 5.5, 3.38, 0.624, 6, .375-24UNF-3A, 0.500, 0.500, 0.500
SAE #2 0.375, 4.750, 6.0, 3.50, 0.624, 6, .375-24UNF-3A, 0.500, 0.500, 0.500
SAE #3 0.375, 5.250, 6.5, 4.00, 0.624, 8, .375-24UNF-3A, 0.500, 0.500, 0.500
The format of the above numbers is:
Bolt Dia (in), Bolt Circle Dia (in), Flange Dia (in), Prop Thickness (in),
Drive Bush Dia (in), Number of Bolts, Bolt Thread, Drive Bush Height (in),
Bolt Minimum Thread Length (in), Max Distance of End of Bolt From Face of
Hub (in)
Generic Dimensions:
Radius on Corners of the Drive Brushes and Flange 0.03-0.06
Main Flange Centre Boss 2.248-2.250 Dia OD and 2.007-2.009 ID, 1.000" Height
above Flange
Radius between flange and Centre Boss 0.190" Max
Radius on Upper Corners of Centre Boss 0.03-0.06"
There is SAE #1 to #6 ... I have only given you the first 3 as these are the
ones that are likely to be on a light aircraft. If you want any more just
let me know.
I hope that helps. Not the same as having the standard but that should be
enough info I think.
"Guy Deraspe" wrote in message
Any good reference?
Guy Deraspe
Old January 12th 15, 12:54 PM
Dave F Dave F is offline
Junior Member
First recorded activity by AviationBanter: Jan 2015
Hi smjmitchell
Any chance of a copy of the full sizes for 1-6 please, I'm wanting to fabricate an adaptor from TCM 360 crank to Lycoming 540 prop for an engine test frame on a dyno.
Dave.
Maule SFSA Tailwheel Information Ron Wanttaja Home Built 1 May 28th 04 12:47 PM
Sun N Fun Information?? DL152279546231 Home Built 2 February 22nd 04 02:22 PM
Any Information on Super Stinker (S1-11B) Martin Morgan Aerobatics 1 December 29th 03 05:34 PM
How to obtain information? Toks Desalu Home Built 1 July 25th 03 07:27 AM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 04:19 PM
