electric plugs
Old January 20th 20, 11:49 AM posted to rec.aviation.soaring
Colin Roney
Default electric plugs
I`m searching for a supplier of a 6 and a 12-way removable
instrument panel plug. Any ideas? Colin
Old January 20th 20, 01:44 PM posted to rec.aviation.soaring
Tango Eight
Digi-Key or Mouser. Happy shopping.
T8
Old January 20th 20, 02:31 PM posted to rec.aviation.soaring
Cookie
https://www.waytekwire.com/item/3863...nnector-Plug-/
Just one example of millions available on the "net"...jsut search!
Cookie
Old January 20th 20, 02:42 PM posted to rec.aviation.soaring
Colin Roney
removable
T8
Thankyou T8
Old January 20th 20, 04:18 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Colin Roney wrote on 1/20/2020 3:49 AM:
Use connectors that use crimped removable contacts, and buy the crimping tool,
too. Or borrow it, but don't cheap it trying to use pliers or solder.
The one that Cookie suggests looks good.
Old January 21st 20, 03:10 PM posted to rec.aviation.soaring
Colin Roney
removable
buy the crimping
tool,
solder.
to ".us" to email
me)
https://sites.google.com/site/motorg...ublications/do
wnload-the-guide-1
Thankyou Eric
Colin
Old January 21st 20, 09:45 PM posted to rec.aviation.soaring
I could think of DigiKey, couldn't remember Mouser....good call in North America.
To original poster....round plug in or "strip connect"?
Amphenol does a ton of connections, way up to "Mil spec"....but expensive.
Lower cost is Amphenol, Phoenix, etc......
Knowing your "style type" helps.
Frankly, real cheap plug in (Sermos/Anderson) can handle major power, good crimps (maybe dielectric grease, soft silver solder, "tweak", etc.) can handle data type connections.
More info from you, better answers from us....have a great day...
Old January 21st 20, 10:55 PM posted to rec.aviation.soaring
How about a 25 pin 'd' connector like old school rs-232?
You might parallel a couple of pins for the power nodes or use a separate anderson clump.
They come in cheap, fancy, solder, crimp, different locking styles, and backshells as you wish.
Old January 22nd 20, 03:01 AM posted to rec.aviation.soaring
The DB line of connectors is what came first to my mind also. You might need 2/3 pins each for power and ground.
I have used stacked PowerPole connectors in a DG pedestal type instrument panel to allow it to be removed for winter play. They dovetail together so nicely and stay connected. Even the smallest pin (three sizes are available) can handle 15 amps!
John (OHM)
Old January 22nd 20, 12:49 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Tue, 21 Jan 2020 19:01:50 -0800, John DeRosa OHM Ω
John (OHM)
Colin, I use DB connectors for all data connections in my cockpit and XLR
connectors for power.
Since I don't like wire tangles and much prefer to have all wiring
removable from the panel so, if needed I can troubleshoot by connecting
instruments that need to communicate with each other on the bench, both
the data and power connection each instrument is a straight cable woth
appropriate connectors at each end. These all terminate on at a small
metal box (for RF interference limiting) that is mounted behind the
panel. I've found that putting the DB connectors on a row on the box and
using a good selection of coloured, insulated wire makes doing the
interconnections super-easy and reliable.
All my DB connectors use either screws or clips to retain them: screws
are best, but some instruments use clips. Needless to say all have metal
covers fitted.
XLR connectors were developed for professional audio use. They have three
pins and are rather substantial. Our club uses them for battery
connections in all our club gliders.
Both DB and XLR connectors are easy to find RS and Farnell both have them
and so do Rapid Electronics https://www.rapidonline.com - Rapid is good
for dealing with small orders over the 'net.
Martin | martin at
Gregorie | gregorie dot org
English Electric Lightning pics 1 [03/10] - English Electric Lightning (probably F.3) landing at Filton, Bristol, England.jpg (1/1) Miloch Aviation Photos 0 July 4th 17 03:34 PM
RFQ Igniter plugs Juan*Jimenez Aviation Marketplace 0 April 23rd 04 11:13 PM
Shields for C-26 plugs Ed Byars Restoration 0 January 23rd 04 08:20 PM
GPS ext power plugs Dave Martindale Piloting 0 September 16th 03 09:26 PM
GPS ext power plugs Dave Martindale Products 0 September 16th 03 09:26 PM
