Looking for water ballast system for DG 200 complete and or parts of.
Old February 10th 20, 11:07 PM posted to rec.aviation.soaring
Chris Stratton
Default Looking for water ballast system for DG 200 complete and or parts of.
Hello,
I'm looking for all the hardware for a water ballast system for a DG 202 1982. An old set of water bags that i could copy would be welcome. Someone removed the whole setup and I'm looking to reconstruct it.
Thanks
Chris Stratton
Old February 11th 20, 12:02 AM posted to rec.aviation.soaring
Bob Kuykendall
Either Streifeneder or DG-Flugzeugbau can probably help you with the bags and valves.
When I was designing the dump system for the HP-24, I couldn't find anything commercially available, so I ended up making my own valves from commercially available components. I considered several suppliers for the bags before going with Streifeneder. The price was reasonable, and the bags were good quality and matched the drawings exactly.
Just curious, are there dump ports in the bottom of the wing? Or does the system dump through the fuselage?
--Bob K.
Old February 11th 20, 01:06 AM posted to rec.aviation.soaring
Hey Bob, did you consider using one of the wake board ballast bag manufacturers? They list a custom option usually with prices starting at $100. I haven't called but expect to use the old bags I have for a while.
Old February 11th 20, 06:06 PM posted to rec.aviation.soaring
Bob Kuykendall
I considered several local makers of pond and tank liners before going with Streifeneder. The money saved didn't seem worth the time and risk. When I started developing sailplanes, I decided that there were several technologies I would leave to others, and ballast bags became one of them. The other big one is acrylic transparencies.
--Bob K.
Old February 11th 20, 08:31 PM posted to rec.aviation.soaring
Chris,
You might consider putting this question on the DG gliders group on groups.io.
https://groups.io/g/DGgliders
Mark
ASW 17 water ballast system OregonGliderPilot Soaring 2 August 18th 19 04:55 PM
water ballast 6PK Soaring 16 July 15th 15 01:43 PM
Water Ballast Tripod [email protected] Soaring 3 July 31st 12 05:43 PM
DG-300 Water Ballast Bags noel.wade Soaring 7 February 18th 10 02:39 AM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
