Defrost blower?
Old March 24th 05, 03:16 AM
John S
Default Defrost blower?
Can someone suggest a low-current, light-weight, inexpensive 12 volt fan to
use in the defrost branch of the cabin heat line for clearing up a
windscreen while still on the ground, when ram air from the prop may not
amount to much? thanks
Old March 24th 05, 03:47 AM
Morgans
"John S" wrote in message
ink.net...
to
Scrounge through some dead computers. Some of the muffin fans are about the
size of a scat tube, and put out a substantial amount of wind. They also
happen to be 12 volt DC.
Old March 24th 05, 10:39 PM
On Thu, 24 Mar 2005 03:16:11 GMT, "John S"
Many hair driers have 12 volt dc blowers in them. I used a pair of
them in my electrified Fiat 128 for defrosters. Used another one for a
motor cooling fan.
When I scrapped the fiat I saved one of them and used it for blowing
up an air-bed for camping.
Old March 25th 05, 12:56 PM
Bushy Pete
Or try your local car wreckers. The heater fans are quite powerfull in many
models and run quite happily on 12 volts with hot air as well.
Hope this helps,
Peter
to
motor cooling fan.
Old March 25th 05, 10:46 PM
On Fri, 25 Mar 2005 11:04:23 -0500, Bryan Martin
They're also quite heavy and way over powered for this application. A small
computer fan would do the job nicely for way less weight and electrical
load.
Not to mention the fans are virtually ALL built into the heater
assembly, and being squirel cages, are useless outside the case.
in article , Bushy Pete at
wrote on 3/25/05 7:56 AM:
Hope this helps,
Peter
to
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) Peter Stickney Military Aviation 45 February 11th 04 04:46 AM
High Altitude operations (Turbo charge???) Andre Home Built 68 July 11th 03 11:59 PM
