FL 2004 - Brakes will not release
Old March 25th 05, 04:04 AM
James
Default FL 2004 - Brakes will not release
I have not used my Microsoft Flight Simulator 2004 in about six months. I
tried to use it this week and I encountered a problem. I can not get the
brakes to release. Pressing the period on the key board or pressing the
trigger button on the Joy stick does not work. It does not matter if I go
to a saved flight or if I create a new one, it is the same thing, the brakes
are on and will not release. Changing aircraft has no effect. I tried
uninstalling the program and then reinstalling it. After reinstalling the
program I was really surprised that I still have the brake on problem.
My computer far exceeds the requirements for FL 2004 even with the program
at the highest settings. My Joy stick is a, Logitech Extreme 3D Pro. The
program worked perfectly for months. So I am truly puzzled at why this
problem has come up and persist even after removing FL 2004 from my computer
and reinstalling it. If you have any ideas I would appreciate your help.
Thanks. James
Old March 25th 05, 04:09 AM
Carl Frisk
What does Settings -- Control Assignments show?
This information is kept in the FS9.cfg file which is not erased if you uninstall.
You could simply backup/rename this file start FS9 and it will build a new one.
....Carl Frisk
Anger is a brief madness.
- Horace, 20 B.C.
http://www.carlfrisk.com
"James" wrote in message ...
Thanks. James
Old March 26th 05, 07:04 PM
James
"Carl Frisk" wrote in message
news:shL0e.25455$mq2.17946@trnddc08...
uninstall.
one.
...Carl Frisk
- Horace, 20 B.C.
I finally got the brakes to work right. Thanks a lot I really appreciate
your help.
I found the file FS9.cfg and deleted it. Then I uninstalled FS-2004. I
reloaded the program once again and now everything seems to work fine.
James
Old March 27th 05, 04:23 AM
Carl Frisk
You probably didn't need to uninstall. FS9 will simply rebuild a new FS9.cfg whenever you start it up again.
....Carl Frisk
- Horace, 20 B.C.
uninstall.
one.
...Carl Frisk
- Horace, 20 B.C.
your help.
James
27 Apr 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 April 28th 04 12:54 AM
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 3rd 04 12:15 AM
Machinista 2004 - call for entries Robb Mitchell Machinista.org Home Built 0 February 24th 04 03:19 PM
30 Jan 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 January 31st 04 04:55 AM
09 Jan 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 January 9th 04 11:05 PM
