Cobra Trailer Fuselage Dolly Strap
Old February 27th 20, 02:49 PM posted to rec.aviation.soaring
Default Cobra Trailer Fuselage Dolly Strap
Anyone have advice for replacing the fuselage dolly strap for a cobra trailer? I got an estimate from Spindelberger and it's reasonable for the strap but the shipping is a bit much.
Also, what's the best method to make the holes into the strap for attaching to the dolly?
Thanks
David
Old February 27th 20, 02:59 PM posted to rec.aviation.soaring
Tim Taylor
Thanks
David
Wings and wheels sells them. I used a heated cork borer, but any small metal tube about the size of the bolts will work to make a hole that will not rip out. Get it hot enough to melt through the webbing.
Old February 27th 20, 03:03 PM posted to rec.aviation.soaring
AS
Thanks
David
David - you can buy the webbing from various sources. To make the hole, I use a hole-punch, which stamps out a nice sharp hole. I then use a lighter to 'cauterize' the open fibers. Put two holes into the end of the strap and double it over. Use two fender washers (one on each side of the strap) to spread out the load and give it a good pinch.
Uli
'AS'
Old February 27th 20, 07:18 PM posted to rec.aviation.soaring
Don't know when they were used but my 1992 Cobra has aluminum "straps". They're fairly stout strips bent to provide clearance from the fuselage (and padded). They're bolted to and pivoting on the dolly at the lower end. At the upper end, there's a plastic bushing that slides over the front fuselage carry-through pin and is held in place by a clip inserted in a hole drilled in the end of the pin.
I had thought they were fairly common but I mostly see the webbing straps now.
They're more expensive to make. And they can be a little more work to align when derigging. But after pushing my previous glider's fuselage out of the dolly when it jammed rolling it into the trailer and once discovering that the dolly had slid part way out from under the fuselage while trailering, I would install these on any new trailer, not that I anticipate getting a new trailer.
Chip Bearden
JB
Old February 27th 20, 09:36 PM posted to rec.aviation.soaring
Chip Bearden
JB
Aluminum straps are common for ships with lift pins on the fuselage(ex. Schleicher). One benefit, beyond keeping the dolly under the fuselage, is that they keep it upright. This has saved more than one canopy.
Straps are almost universal on ships that have lift pins on the wings(SH, Glasflugel, etc). I much prefer solid straps and have added to a few rigs, including SH.
UH
Ka6 CR fuselage dolly [email protected] Soaring 1 February 14th 17 12:33 AM
Lining fuselage dolly Colin Roney Soaring 0 April 26th 14 10:19 AM
Cobra trailer wing dolly plastic sidewall rollers? [email protected] Soaring 4 May 9th 13 10:52 PM
Asw20 fusalage dolly wanted for cobra trailer Gregg Leslie[_2_] Soaring 2 January 14th 13 03:22 AM
ASK-21 fuselage dolly bildan Soaring 8 August 1st 10 05:43 PM
