Breguet-Richet Gyroplane
Old July 16th 19, 02:42 PM posted to alt.binaries.pictures.aviation
Miloch
Default Breguet-Richet Gyroplane
https://en.wikipedia.org/wiki/Breguet-Richet_Gyroplane
The Breguet-Richet Gyroplane was an early French experimental quadcopter
rotary-wing aircraft developed by Breguet Aviation.
The Gyroplane No.I was one of the earliest attempts to create a practical
rotary-wing aircraft. It was designed by the Breguet brothers with help from
Professor Charles Richet. The aircraft had an uncovered open steel framework
with a seat for the pilot and a powerplant at the centre. Radiating from the
central structure were four wire-braced tubular steel arms, each bearing a
superimposed pair of four-bladed rotors. To eliminate the torque effect, two
rotor sets were driven clockwise and two counter-clockwise.
Role
Rotary-wing test vehicle
Manufacturer
Breguet
Designer
Louis Breguet
First flight
29 September 1907
Number built
2
On 29 September 1907, the Gyroplane No.I was flown for the first time, albeit to
an elevation of only 0.6 metres (2.0 ft). It was not a free flight, as four men
were used to steady the structure. It was neither controllable nor steerable,
but it was the first time that a rotary-wing device had lifted itself and a
pilot into the air. It later flew up to 1.52 m (4.99 ft) above the ground. The
design was improved and the Gyroplane No.II appeared the following year. No.II
had two two-blade rotors of 7.85 m (25.75 ft) diameter and also had fixed wings.
Powered by a 41 kW (55 hp) Renault engine, it was reported to have flown
successfully more than once in 1908. No.II was damaged in a heavy landing and
was rebuilt as the No.IIbis. It flew at least once in April 1909 before being
destroyed when the company's works were badly damaged in a severe storm.
Specifications (No.I)
General characteristics
Crew: one
Height: 3.7 m (12 ft 2 in)
Empty weight: 500 kg (1,102 lb)
Gross weight: 578 kg (1,274 lb)
Powerplant: 1 × Antoinette water-cooled piston engine, 34 kW (46 hp)
Main rotor diameter: 4× 8 m (26 ft 3 in)
Main rotor area: 402.2 m2 (4,329 sq ft) biplane rotors
Performance
Endurance: 1 minute
Service ceiling: 0.6 m (2.0 ft)
Breguet-Richet Gyroplane pics 2 [4/5] - breguet-richet_gyro07_4_000.jpg (1/1) Miloch Aviation Photos 0 February 1st 18 12:26 PM
Breguet-Richet Gyroplane pics 2 [3/5] - breguet-richet_gyro07_1_500.jpg (1/1) Miloch Aviation Photos 0 February 1st 18 12:26 PM
Breguet-Richet Gyroplane pics 2 [2/5] - Breguet-Richet Gyroplane.jpg (1/1) Miloch Aviation Photos 0 February 1st 18 12:26 PM
Breguet-Richet Gyroplane pics 2 [1/5] - Breguet-Richet Gyroplane No 1.jpg (1/1) Miloch Aviation Photos 0 February 1st 18 12:26 PM
Breguet-Richet Gyroplane pics - . Bréguet Richet Gyroplane No. 1.jpg ... Miloch Aviation Photos 0 February 1st 18 12:24 PM
