GTAW / TIG filler material recommendations
Old July 1st 03, 09:06 PM
Jari Kaija
Default GTAW / TIG filler material recommendations
(same as "OK Autrod 13.13",
Darn... OK TIGROD 13.13...
Old July 1st 03, 10:20 PM
Patrice
I found that article about welding 4130 in the
Lincoln web site.
http://www.lincolnelectric.com/knowl...hrome-moly.asp
Best Regards
Patrice/C-FRSH
"Jari Kaija" a écrit dans le message de
Most recommended filler material for 4130N TIG weldings
seems to be: AWS ER70S-2
However. Can I use ER 100S-G (same as "OK Autrod 13.13",
what I have already... a lot..) without preheating & post-weld
heat treating?
Otherwise I need to go tomorrow to local hardware strore...
-Jari / OH-XJJ
www.jarikaija.com
www.project-ch701.net
(Spammers! All spam messages will be deleted automatically
from server, so, save your miserable time...)
Old July 1st 03, 10:35 PM
Jari Kaija
Lincoln web site.
Had it already. I have PDF version of similar kind of article
in my web site also.Very informative article, but it doesn't resolve
my question about 13.13.
http://www.project-ch701.net/ch701_misc/FAQ4130N.pdf
-Jari / OH-XJJ
www.jarikaija.com
Old July 2nd 03, 02:35 AM
funnyman
I would stick to ER70S-2, ER70S-6, or ER80D-2. I use ER70S-2 all the
time and I like the way it flows better than ER70S-6.
Old July 2nd 03, 04:04 AM
Del Rawlins
On 01 Jul 2003 05:35 PM, funnyman posted the following:
I tried some ER70S-6 for the first time last week (TIG welding) on my
toe brake pedals and that was my experience as well. It works fine, but
the S-2 seems to leave a nicer bead. The S-6 tended to come out looking
a little like a MIG bead which makes sense because the S-6 alloy is
normally used for MIG wire. I'm perfectly happy with the performance of
either alloy and once I exhaust my supply of S-2 I will burn up the S-6
I just bought before I buy any more rod.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old July 2nd 03, 11:59 PM
Bruce A. Frank
Del,
Was the rod you used copper plated? Did you remove it, the copper,
before using the rod? (polish it with Scotch Brite) I ask because almost
everyone with whom I have spoken finds the -6 produces a nicer bead and
much quieter molten puddle (than -2) when TIG welding (fewer sparks
flying contaminating the tungsten).
Bruce A. Frank
Del Rawlins-
Old July 3rd 03, 03:31 AM
funnyman
"Bruce A. Frank" wrote in message ...
Del,
I never remove the copper. Sounds like your friends aren't cleaning
the base metal very well. Since ER70S-6 has more deoxidizers it will
weld better on unclean metal. Most of the time with ER70S-2 on clean
4130 you will never see sparks or contaminates coming off. As with
any welding it will always be better to start with cleaning the metal.
Once you have clean metal 70S-2 will make a much nicer bead than
70S-6. With dirty metal 70S-6 will have a nicer bead than 70S-2.
Old July 3rd 03, 04:36 AM
Bruce A. Frank
Most wipe it with some type of de-oiler...acetone or something similar,
but the mill scale is still there as usually no bead blasting is done
before welding. Straight argon cover gas.
Del,
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
