Condor is exasperating
Old April 7th 20, 03:56 AM posted to rec.aviation.soaring
jp
Default Condor is exasperating
My difficulties with Condor may well be due to my using bootcamp into Windows 10 on my Mac. However,
I have copied a new landscape directory into the c:/Condor2/Landscapes directory and it is not presented for selection on the Tasks screen.
I also just purchased an additional glider (ASK-21) and I have not received it, as far as I can figure out, and I have been unable to find any FAQ or other assistance for this.
I am done.
Old April 7th 20, 04:10 AM posted to rec.aviation.soaring
Paul Agnew
I am done.
Is is a subdirectory in the Landscapes folder? Are you manually installing the landscapes?
There's a great install utility that really makes it much easier and you can set it up to put landscapes on a different drive without moving your application.
You can get the Condor Updater he
https://www.condor-club.eu/generic/2...ceneries_.html
Don't throw in the towel, yet. It takes everyone a few tries to get everything in the right place with a new install.
Paul A.
Old April 7th 20, 04:12 AM posted to rec.aviation.soaring
Daniel Sazhin[_2_]
Howdy,
Condor has an extensive support network. See the options he
https://www.condorsoaring.com/help/
If you contact them directly, they are pretty responsive.
Feel free to contact me at my blog contact https://soaringeconomist.com/contact-info. If you have a simple problem I may be able to help you.
All the best,
Daniel
Old April 7th 20, 04:27 AM posted to rec.aviation.soaring
Larry Suter
JP- when I unzip a scenery it often puts the folder with the scenery data inside a folder with exactly the same name. If you put this "folder within a folder" into your Landscape folder, Condor won't recognize the scenery. The fix is to just put the innermost folder into the Landscape folder.
When you purchase a glider you should have received an email with the license key for activating the glider. Choose the ASK-21 in the Hanger and there should be a button on the lower-right of the screen that says "Activate". Click it and a pop-up window should ask for the license key.
Good luck,
Larry
Old April 7th 20, 05:15 AM posted to rec.aviation.soaring
Paul Agnew
I am done.
Here;s a discussion about Macs and options to run Condor:
http://www.condorsoaring.com/forums/...tcamp #unread
Old April 7th 20, 05:18 AM posted to rec.aviation.soaring
Paul Agnew
I am done.
Here's a discussion about Macs and options to run Condor:
Old April 7th 20, 08:10 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
I am done.
When you buy an additional glider, you need to download and install the Hangar Update from the Condor website. It's on this page
https://www.condorsoaring.com/downloads-2/
This is described in a paragraph on the "Buy" page of the site.
Old April 7th 20, 09:48 PM posted to rec.aviation.soaring
jp
I am done.
Yes, thank you Chris. I missed that on the "Buy" page. I have just increased the partition size of my BOOTCAMP partition and then downloaded the Hanger Update. After that I was able to select and then activate the ASK-21 glider I had purchased. Now if I just need to figure out why the landscape directory I copied to the C:\Condor2/Landscapes directory is not seen by Condor. I'll figure it out.
Old April 7th 20, 11:43 PM posted to rec.aviation.soaring
Dan Marotta
The two slashes bracketing Condor2 are opposites.Â* Is that correct or a
typo?
I am done.
Dan, 5J
Old April 8th 20, 12:37 AM posted to rec.aviation.soaring
jp
typo?
I am done.
Dan, 5J
Hi Dan,
Just stupidity on my part. They should be the same.
Curtiss B-2 Condor pics 3 [2/8] - Eastern Air Transport CO Condor.jpg (1/1) Miloch Aviation Photos 0 August 30th 18 12:26 PM
Curtiss B-2 Condor pics [01/11] - B-2 civilian version Model 53 Condor 18.jpg (1/1) Miloch Aviation Photos 0 August 30th 18 12:20 PM
Curtiss T-32 Condor II pics 1 [02/11] - 1930s-passengers-boarding-american-airlines-condor-biplane-airplane-AAMYTR.jpg (1/1) Miloch Aviation Photos 0 November 17th 17 02:38 PM
Curtiss T-32 Condor II pics 1 [01/11] - 1007-condor.jpg (1/1) Miloch Aviation Photos 0 November 17th 17 02:38 PM
Condor Thanksgiving and Condor Christmas Contests [email protected] Soaring 0 October 22nd 12 03:33 PM
