I have been searching the FAA regulations for information who is authorized
to sign off Com/Nav or avionic equipment installation or replacement. For now this is hypothetical. I have 5 years experience in aircraft maintenance from the Air Force and 6 years experience as a radio technician. I hold a valid General Radio Telephone license but no A&P certification. I have the general knowledge but am unaware of what authority my FCC license allows and am having trouble finding the information the regs. Can someone please tell me what regulations govern certifications requirements for a avionic sign-off? Based on Part 43, I know radio and navigation system work is "major" and therefore regulated. I also know if installing a new radio, an A&P would be required to sign-off any structural and weight and balance aspects of the install. Does a new radio also require a second sign-off from an FCC license holder? What about a new ODI or an GPS? Again this is hypothetical. At the moment I am toying with the possibility of pursuing the credentials to become a certified avionic technician. Thanks. Dave Salvagnini 2W5 - Maryland |
![]() "David Salvagnini" wrote in message ... I have been searching the FAA regulations for information who is authorized to sign off Com/Nav or avionic equipment installation or replacement. For now this is hypothetical. Don't bother. You won't find anything. Can someone please tell me what regulations govern certifications requirements for a avionic sign-off? The same ones that require an A&P's siggy on anything installed into the aircraft. Based on Part 43, I know radio and navigation system work is "major" and therefore regulated. Then you need remedial work on reading regulations. That is blatantly false. I also know if installing a new radio, an A&P would be required to sign-off any structural and weight and balance aspects of the install. That is correct. Does a new radio also require a second sign-off from an FCC license holder? No. What about a new ODI or an GPS? No. No. Jim |
possibility of pursuing the credentials to become a certified avionic technician. Thanks. If you want to repair radios, you will have repair and return to service authority only in association with a certified repair station. So your choices will be limited to working for a certified repair station which in english means an established avionics shop, or opening your own repair station and being the certified repairman for it. You can't just work out of the back of your pickup truck and be a certified repair station. See Part 145. If you just want to install radios yourself, you can become an A&P and don't need be an "avionics technician." Or you can install the radios yourself and get somebody licensed to check the work and sign it off, which is the preferred method if you're not looking a new career. |
The regulations seem to be deliberately written to prohibit exactly
what you are wishing to do. Seems like no "freelance" avionics guys are to be allowed in business. The FAA only wants certificated A&P mechanics and certificated repair stations working on certificated airplanes, and lately there seems to be some kind of subtle pressure to begin elimination of the independent A&P mechanic too and try to make all airplane work required to be done at certificated repair stations with lots of extra bureaucratic oversight and scrutiny. |
Adding IFR Plane Certification To Planes Without It | Blanche Cohen | Owning | 10 | November 29th 04 06:37 PM |
Aircraft certification questions. | psyshrike | Home Built | 40 | November 22nd 04 06:10 PM |
Aircraft certification questions. | psyshrike | Owning | 42 | November 22nd 04 06:10 PM |
certification of composite aircraft | sebastian | Home Built | 6 | March 25th 04 03:48 PM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
