Record height for a winch launch?
Old April 17th 20, 07:15 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Default Record height for a winch launch?
New people always ask about release altitudes. The more relevant question is the rate of launches. We learn to fly and gain proficiency through repetition, we gain altitude in thermals. Ever ask the guy doing pattern work in a 172 how high he got?
For most licensed pilots I think the release height is very important.
If you go to all the trouble to get ready to go soaring, you want to get high enough to have a good chance to get away.
Nick
T
Old April 17th 20, 11:24 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Nick T
On a reasonable day 1400 is enough and less good days typically just take
a bit longer to get going. Occasionally you get lucky too. A year or two
back I took a launch around lunchtime, which I abandoned at 1000 ft due
to a sudden overspeed. Thought it might be a thermal, so whipped the
wheel up, hung a 180 and came straight back down the middle of the
runway. Met it at 900ft - a very small tight thermal that immediately
showed 5-6 kts up. Got my Libelle nice and tight in it and noticed the
averager showing 13 kts as I went through 3500. Unfortunately I had to
leave at 4700 or so because we're under under the outer shelf of
Stanstead CTR and its base is 5500.
Dunno if you have the sort of odd conditions we sometimes get, but there
are times on a calm day when there's very little lift under 1800-2000, a
nasty trap if you'd towed to 2500 and didn't notice the dead lower
regions, but by starting from a winch launch to 1400 I'll certainly know
if its that sort of day.
Martin | martin at
Gregorie | gregorie dot org
Old April 17th 20, 11:53 PM posted to rec.aviation.soaring
AS
Nick
T
I beg to differ! Last weekend, one of our guys encountered a rope break at 1,000ft (an old splice let go) and not only did he have the audacity to climb away, he also went XC! He broke all the rules commonly known to be associated with winching!
Uli
'AS'
Old April 18th 20, 12:13 AM posted to rec.aviation.soaring
Nick T
I'd do the same if in the right circumstances, as would any of our
pilots. Besides, high key for starting a circuit from the winch end of
our airfield is 700 ft, so on a good day the chance of sniffing out a
bump from 1000 ft is quite good.
Martin | martin at
Old April 18th 20, 03:22 AM posted to rec.aviation.soaring
So not my story but one of our pilots was giving a winch ride to a elderly woman ( 86 or so) first flight ever, when we had a wire break at 800 feet. It was a resonable day with 4-5 knot thermals, and he says out loud "I think I can save it" and she says "do the best you can". Well he managed to do a climb to 3-4k agl and they had a hour flight before landing. She exclaimed after landing She was glad she didnt die after that! Its all about your mindset and syntax ðŸ˜ðŸ˜ðŸ˜
Old April 19th 20, 07:00 PM posted to rec.aviation.soaring
Nick
T
Uli
'AS'
Uli, you can do the same from an aero-tow, just go ask our club tow pilots. Sometimes I get questions from them like "Why are you still hangin' on, what's wrong with you - at 1,600'.
Old April 19th 20, 10:53 PM posted to rec.aviation.soaring
Nick
T
Uli
'AS'
Old April 20th 20, 01:35 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Nick
T
Uli
'AS'
Hi Uli
Could you elaborate on the supposedly broken rules so we can learn more re winch launching?
TIA
Colin
Old April 20th 20, 10:10 AM posted to rec.aviation.soaring
Dave Walsh[_2_]
more relevant
proficiency
guy doing
important.
you want to
Nick
T
a rope break
audacity to
known to be
I recall way back in history that, given enough wind, the pilot
would be winched to the maximum height then the winch driver
would very slowly let out cable with the glider still attached. With
the cable fully out the winch driver then applied power and a
"second" climb followed. Never witnessed this but was told it
happened in the UK back in the '60s. Anyone remember hearing
this tale? Wouldn't be difficult to get 3000'+ on a decent sized
airfield.
Uli
'AS'
club tow
still hangin'
Old April 20th 20, 02:50 PM posted to rec.aviation.soaring
more relevant
proficiency
guy doing
important.
you want to
Nick
T
a rope break
audacity to
known to be
airfield.
Uli
'AS'
club tow
still hangin'
We used to do kiting regularly in the 1960s with T-21's and two lightweight pilots, took about 20 minutes to get to 3,400' which was the highest I ever got. Rules were very different then.
Record height for a winch launch? [email protected] Soaring 11 April 17th 20 07:46 PM
Record height for a winch launch? [email protected] Soaring 13 December 6th 16 03:16 PM
Record height for a winch launch? firsys Soaring 2 December 2nd 16 09:00 PM
Record height for a winch launch? Tom BravoMike Soaring 0 December 2nd 16 03:12 PM
