Condor website down ?-want to use Oudie with Condor
Old April 18th 20, 06:07 PM posted to rec.aviation.soaring
Default Condor website down ?-want to use Oudie with Condor
Hi All
I get an error message when I try to join the forumn.
I want to connect my Oudie 2 to Conbdor on my PC.
I guess I need a cable from one of the suppliers. Anyhing else ?
Dan
Old April 18th 20, 06:18 PM posted to rec.aviation.soaring
Paul Agnew
I believe you can connect an Oudie2 via Bluetooth using a virtual serial port app.
Paul A.
Old April 18th 20, 08:37 PM posted to rec.aviation.soaring
Paul Remde
Hi Dan,
The Oudie or Oudie 2 (not Oudie IGC) must be connected to Condor using a serial data connection, so a standard USB cable doesn't work. I haven't had any luck with Bluetooth connections between an Oudie and Condor. I recommend the Goddard Condor-Oudie-1p5 cable. It looks like a USB cable but has a built-in serial data to USB converter. There are 2 versions available.
http://cumulus-soaring.com/goddard.htm#Condor-Oudie-1p5
http://cumulus-soaring.com/goddard.h...Oudie-Rev2-1p5
I have both versions in stock.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_____________________________________
On Saturday, April 18, 2020 at 12:07:50 PM UTC-5, wrote:
Hi All
Dan
Old April 18th 20, 10:45 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
On Saturday, April 18, 2020 at 7:07:50 PM UTC+2, wrote:
Hi All
Dan
Its back up again.
Old April 18th 20, 11:06 PM posted to rec.aviation.soaring
Sooo....the site took Viagra?....LOL.....
New Oudie 2 Condor 2 cable connection Nelson Howe Soaring 11 February 12th 20 04:50 PM
Curtiss B-2 Condor pics 3 [2/8] - Eastern Air Transport CO Condor.jpg (1/1) Miloch Aviation Photos 0 August 30th 18 12:26 PM
Curtiss B-2 Condor pics [01/11] - B-2 civilian version Model 53 Condor 18.jpg (1/1) Miloch Aviation Photos 0 August 30th 18 12:20 PM
Curtiss T-32 Condor II pics 1 [02/11] - 1930s-passengers-boarding-american-airlines-condor-biplane-airplane-AAMYTR.jpg (1/1) Miloch Aviation Photos 0 November 17th 17 02:38 PM
Oudie and Condor GeneReinecke Soaring 5 June 10th 15 05:55 PM
