Hisense A5 e-Ing phone
Old May 1st 20, 10:40 PM posted to rec.aviation.soaring
Default Hisense A5 e-Ing phone
Hi,
Has anyone run TopHat on one if those?
Or anything else like xcsoar etc..
S
Old May 7th 20, 01:03 AM posted to rec.aviation.soaring
6PK
Someone else just posted about this. Sounds interesting but proof is in the pudding....
Old May 7th 20, 11:32 PM posted to rec.aviation.soaring
Stephen Szikora
Some guys in my club are running XCSoar on the Yotaphone 2. It is no longer made and the company went bankrupt but it was an interesting phone because it had a regular LCD screen on one side, and an e-ink screen on the other. It was configured to be able to mirror which meant the e-ink side could be used like any android phone (just a different screen.) The Yotaphone 3 was also a dual screen phone but it wasn’t a true mirror set up so the e-ink side was more limited. There are a couple of e-ink phone manufacturers with Hisense - a Chinese company - being the leader (I think they were involved with Yotaphone - a Russian company - for manufacturing) I have seen XCSoar running on the Yotaphone and the performance is very good because the screen quality is better than a typical e-reader, the processing power of the phones are much better, and asa result there isn’t as much of the screen refresh slowness and ghosting typical of e-ink screens. Another one introduced this year but I don’t think on sale yet is called the Onyx and it features capabilities to adjust screen refresh rates. I also posted about the new one from Hisense - with a colour e-ink screen. A little colour is all we need for XCSoar so I think it will be ideal. In fact, any of these e-ink android phones are just the ticket compared to modding Kobos and the like. As a bonus, they are not expensive compared to other cell phones.
Old May 8th 20, 12:19 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Thu, 07 May 2020 15:32:42 -0700, Stephen Szikora wrote:
I also posted
Interesting. Do you know if anybody sells these e-ink (either monochrome
or colour) for use with a RaspberryPi? THAT would be very interesting
indeed. I have a 4" diagonal TFT colour touch screen with 480 x 320 res
that I'll put on a RPi when I get a round tuit. I'm planning to run XK8000
on that, but a colour or monochrome eInk touch screen would most likely
be more readable in the cockpit.
Martin | martin at
Gregorie | gregorie dot org
Old May 8th 20, 01:03 AM posted to rec.aviation.soaring
Stephen Szikora
I don’t know about that but I’ll do some searching. One thing I forgot to mention is that the Hisense phones don’t have Google Play. The Onyx one does. Not a big deal because you can load XCSoar directly and anything else you need directly also. I should highlight that these phones all have GPS (making it easy to get up and running compared to a Kobo) but none of the ones I mentioned have a barometric sensor.
Old May 8th 20, 09:51 PM posted to rec.aviation.soaring
Phil Plane
Check this out:
https://github.com/lyusupov/SoftRF/wiki/SkyView-Pi
It's not completely what you're after, but it's getting there.
Phil Plane
Old May 9th 20, 12:00 AM posted to rec.aviation.soaring
monochrome or colour) for use with a RaspberryPi? THAT would be very
interesting indeed. I have a 4" diagonal TFT colour touch screen with
480 x 320 res that I'll put on a RPi when I get a round tuit. I'm
planning to run XK8000 on that, but a colour or monochrome eInk touch
screen would most likely be more readable in the cockpit.
Check this out:
Agreed! This one is even better:
https://www.waveshare.com/4.2inch-e-Paper-Module-B.htm
and this is better still, though not e-Ink:
https://www.waveshare.com/product/ra...-oled/4.3inch-
dsi-lcd.htm
It is dual colour (black/red on white) and the size is pretty much ideal.
Ideally I'l find a screen thats almost the same size ad thr Medion (3.5"
screen but wide bezel (4.4" x 3.2" - 80 x 105mm) Its mounted on a flexi
mount in front of my panel. Anything bigger than that and I start to
loose sight of my radio and backup vario behind it. I fly a Libelle, so
having stuff mounted where it sticks out past the panel edge is not an
option.
However, to control LK8000 (or XCSoar) I could really do with a touch
screen. So far, the best screen I've seen is this:
Pimoroni HyperPixel - 4.0"
https://thepihut.com/collections/ras...cts/hyperpixel
.... I got one to experiment just before they went out of stock in early
March and AFAIK haven't yet reappeared, but that may be COVID rather than
lack of interest in making any more.
BTW both XCSoar and LK8000 have been ported to the RaspberryPi, which is
why I keep banging on about that hardware, and Pimoroni do some very nice
addons, such as a PSU board that supplies 5v regulated from a 1S LiPo
battery and can charge it from an external 5v supply while also driving
the Pi.
Martin | martin at
Old May 8th 20, 03:55 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Don't want to offend anyone or step on any toes, but you guys have heard of a Naviter device called a OUDIE haven't you?
Works GREAT
Not too expensive
Full of goodies
Nick
T
Old May 8th 20, 02:21 PM posted to rec.aviation.soaring
Works GREAT Not too expensive
Still, AFAIK, based on WinCE which has been obsolete & unsupported by M$
for a long time now.
FWIW I'm currently flying with LK8000 running on a Medion S.3747. Its
also WinCE based, but has a transreflective display, barograph and GPS
and, as a nice touch, an easily swappable battery, but its going to die
sooner or later.
Hence my interest in the bits needed to build a replacement.
Martin | martin at
Old May 9th 20, 08:21 AM posted to rec.aviation.soaring
krasw
Oudie users do not care about the operating system, because it is hidden from the user. If it is obsolete and unsupported, so what? It works, day after day, year after year.
LG-980 PDA/Phone for sale Don Grillo Soaring 0 January 23rd 15 10:51 PM
Who's on the phone? Mxsmanic Piloting 5 January 10th 10 07:38 PM
Enjoy High Quality incredible low cost PC-to-phone and broadband phone services John Home Built 0 May 19th 05 02:58 PM
Phone gun Paul Sengupta Piloting 12 February 13th 04 11:09 PM
