Lockheed T2V SeaStar
Old September 20th 19, 02:59 PM posted to alt.binaries.pictures.aviation
Miloch
Default Lockheed T2V SeaStar
https://en.wikipedia.org/wiki/Lockheed_T2V_SeaStar
The Lockheed T2V SeaStar, later called the T-1 SeaStar, is a carrier-capable jet
trainer for the United States Navy that entered service in May 1957. Developed
from the Lockheed T-33, it was powered by one Allison J33 engine.
Starting in 1949, the U.S. Navy used the Lockheed T-33 for land-based jet
aircraft training. The T-33 was a derivative of the Lockheed P-80/F-80 fighter
and was first named TO-2, then TV-2 in Navy service. However, the TV-2 was not
suitable for operation from aircraft carriers. The persisting need for a
carrier-compatible trainer led to a further, more advanced design development of
the P-80/T-33 family, which came into being with the Lockheed designation L-245
and USN designation T2V. Lockheed's demonstrator L-245 first flew on 16 December
1953 and production deliveries to the US Navy began in 1956.
Compared to the T-33/TV-2, the T2V was almost totally re-engineered for carrier
landings and at-sea operations with a redesigned tail, naval standard avionics,
a strengthened undercarriage (with catapult fittings) and lower fuselage (with a
retractable arrestor hook), power-operated leading-edge flaps (to increase lift
at low speeds) to allow carrier launches and recoveries, and an elevated rear
(instructor's) seat for improved instructor vision, among other changes. Unlike
other P-80 derivatives, the T2V could withstand the shock of landing on a
pitching carrier deck and had a much higher ability to withstand sea
water-related aircraft wear from higher humidity and salt exposure.
Role
carrier-capable trainer
Manufacturer
Lockheed
First flight
15 December 1953
Introduction
May 1957
Retired
1970s
Primary user
United States Navy
Number built
150
Developed from
Lockheed T-33
The only version of the T2V was initially designated T2V-1 when it entered
service, but was redesignated T-1A SeaStar under the 1962 United States
Tri-Service aircraft designation system,the designation under which it would
spend the majority of its career.
The T-1A was replaced by the North American T-2 Buckeye but remained in service
into the 1970s.
Specifications (T2V-1)
General characteristics
Crew: Two (student & instructor)
Length: 38 ft 6½ in (11.75 m)
Wingspan: 42 ft 10 in (13.06 m)
Height: 13 ft 4 in (4.06 m)
Wing area: 240 ft² (22.3 m²)
Empty weight: 11,965 lb (5,427 kg)
Loaded weight: 15,500 lb (7,031 kg)
Max. takeoff weight: 16,800 lb (7,636 kg)
Powerplant: 1 × Allison J33-A-24/24A turbojet, 6,100 lbf (27.2 kN)
Performance
Maximum speed: 504 knots (580 mph, 933 km/h) at 35,000 ft (10,670 m)
Range: 843 nm (970 mi, 1,560 km)
Service ceiling: 40,000 ft (12,190 m)
Rate of climb: 6,330 ft/min (32 m/s)
Pima museum Batch 9 [30/46] - T2V-1 Seastar DSC_3354.jpg (1/1) Indrek Aviation Photos 0 December 31st 10 12:07 AM
DoubleEnders, pt 6 - Dornier Seastar-2.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 1 February 12th 08 07:05 PM
DoubleEnders, pt 6 - Dornier Seastar-4.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 February 11th 08 12:59 PM
DoubleEnders, pt 6 - Dornier Seastar-3.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 February 11th 08 12:59 PM
DoubleEnders, pt 6 - Dornier Seastar-1.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 February 11th 08 12:59 PM
