Google Earth Pro changes
Old May 7th 20, 08:25 PM posted to rec.aviation.soaring
Default Google Earth Pro changes
Bummer! Bummer! Bummer! Darn you Google!
The current GEP no longer lets user locate by coordinates. Seems Google has also removed the feature allowing map rotation and tilt view. These were a very useful XC/contest soaring features.
Is there some other like mapping software a "broke brother" could afford to use?
Old May 7th 20, 10:19 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
????? Why do you think that?
Paste coordinates into the search box and click "Search" and Google Earth
Pro goes there, just like it has always done. Of course, you need to have
the coordinates in a form it understands, but that's always been the case.
This is GEP 7.3.3.7673 (64-bit) - just tried it with co-ords copied from
a Wikipedia page, which worked as I expected it would. I also swiped TP
coordinates of a crossroad near Cambridge and that woked too with a light
edit: the DAT format is
52:07.750N,000:13.326E which GE doesn't like, so I tweaked it to
52 07.750 N 000 13.326 E which works just fine.
More annoying is the way that Google tends to change where the executable
lives on your computer and what its called just because they can. That is
just as easy to fix by edit your desktop launcher so it knows where GE
now lives and what its called, but some browsers (take a bow, Brave) will
no longer be able to find it and can't be told where it now is. This will
mess up launching it from Wikipedia map pages, but you can still start it
manually and do a cut'n paste with the coordinates.
Plenty of FOSS stuff out there - look for GPS mapping programs, but why
bother? Google Earth Pro works just fine.
Martin | martin at
Gregorie | gregorie dot org
Old May 7th 20, 11:32 PM posted to rec.aviation.soaring
Martin,
Using your format 52 07.750 N 000 13.326 E, GEP does take me to said crossroads near Cambridge.
However, using the same format, GEP will NOT "point":
Condor2 Slovenia2 Lesce-Bled 46.21.392 N 14.10.512 E
Condor2 AA2 Mauterndorf 47.7.992 N 13.41.747 E
USA Minden, NV 39.52.20 N 119.42.04 W
USA Nephi, NV 39.44.193 N 111.52.203 W
USA Driggs, ID 43.44.553 N 111.5.794 W
USA Uvalde, TX 29.12.35 N 99.47.19 W
USA Perry, SC 33.37.37 N 99.47.19 W
So it seems GEP blocks coordinate "points" by country or region. Probably has something to do with airspace security. Perhaps you geodesists or State Department guys can explain. Man, what strange times.
Martin | martin at
Old May 8th 20, 12:05 AM posted to rec.aviation.soaring
But you're not using the same format - there should be *NO DECIMAL POINT*
between degrees and minutes. The only decimal point id in the minutes
valie which is a decimal number. IOW don't use this:
Use this instead:
Slovenia2 Lesce-Bled 46 21.392 N 14 10.512 E
times.
I doubt it: I turned on 'Path in Tools and pasted the first three
coordinates in your line into the search box clicked search, clicked thre
pin, repeated for the second and third points and got a nice yellow path
from 1st-2nd-3rd point, so it does work.
Did you used to generate a KML file and open that with GEP, if so you
should have said so. Personally, when I want to see a flight on GE, I
pull my log into GPLIGC, tell it to export a KML file and then open that
with GE That works too: File:Open says it still accepts .kml files.
If that's not what you expected, kindly say exactly what you expect to
happen when you make a list EXACTLY like you posted, but with properly
formatted co-ordinates.
Martin | martin at
Old May 8th 20, 12:17 AM posted to rec.aviation.soaring
Got it; thanks Martin! Have a lot of love for you smart guys!
What on (Google) Earth... ?? GM Soaring 9 March 28th 08 04:54 AM
Saw This On Google Earth John[_1_] Naval Aviation 3 January 27th 08 12:25 AM
Google Earth Frank Whiteley Soaring 3 November 16th 07 12:36 AM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 04:31 PM
Google Earth ttaylor at cc.usu.edu Soaring 8 September 22nd 05 12:07 PM
