Oil Pressure
Old September 22nd 04, 01:34 PM
Justin H
Default Oil Pressure
Anyone know the acceptable ranges for oil pressure on an o-290 lycoming?
Old September 23rd 04, 01:22 AM
Kyle Boatright
I can tell you that on an 0-320, with a pressure pick-up coming off of the
accessory case, the "green band" is 60-100 PSI in cruise, with as little as
25 PSI OK for idle conditions with a warm motor.
KB
"Justin H" wrote in message
Old September 23rd 04, 04:35 AM
Orval Fairbairn
KB
For the O-435 series, which is the 6-cylinder brother to the O-290
series, the FAA Certification Sheet shows 60 psi min and 85 psi max.
I might point out that both engines use the same rods, rod bearings,
pins, pistons, cylinders and valves. I am not sure about the main
bearings, however.
If you can get hold of the FAA Type Certification Data Sheet, you will
have an accurate answer.
Vacuum "pressure" for gyros Jari Kaija Home Built 3 March 18th 04 05:08 PM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
