PZL Variometer Model No; WRs-5D
Old May 16th 20, 12:13 AM posted to rec.aviation.soaring
Andrew Milner
Default PZL Variometer Model No; WRs-5D
Evening All, I have a problem with my vario reading 1 Knot down and I'd
like
to adjust it back to zero.
I've searched the web for hours looking for an instruction manual but
cannot
find anything about zeroing this particular vario.
Is their anyone out there that can help?
Thanks
Old May 16th 20, 03:28 PM posted to rec.aviation.soaring
john firth
like
cannot
Thanks
you have to remove the faceplate; make a tool which engages in the slots in the
retaining ring. use a few drops of penetrating oil on thecircumference.
Hold the case in a vice with padding.
unscrew counter clockwise; if the glass is stuck use a sucker cup
to lift it off.
Adjustment screw is in the centre of the dial,.
JMF
Old May 17th 20, 02:13 PM posted to rec.aviation.soaring
retaining ring.
A scrap of 1/16 ss with the corners ground nicely worked on my asi, but this looks first class.
https://wingsandwheels.com/avionics-...zel-rings.html
Old May 17th 20, 04:36 PM posted to rec.aviation.soaring
I used a hack saw blade cut to the right length, for my winter altimeter bezel fits nicely and very stiff/hardened.
CH
PZL Variometer Model; WRs-5D Andrew Milner Soaring 2 May 16th 20 04:27 AM
Boeing Model 40 pics 3 [3/4] - Model 40C Pilot's panel with some modern features added for safe operation.jpg (1/1) Miloch Aviation Photos 0 May 27th 19 03:20 PM
Lockheed Model 10 Electra pics 2 [2/8] - Flight deck of a Model 10A, which has been updated with a more modern instrument panel.jpg (1/1) Miloch Aviation Photos 0 February 7th 19 03:23 PM
Need an audio/battery box for a Ball Variometer Model 400/3 [email protected] Soaring 1 February 22nd 14 06:36 PM
Selling a spare 80 mmm Sage Variometer Model 'CV' Uwe Kleinhempel Soaring 0 October 20th 11 04:56 PM
