Magtape Xtra
Old May 23rd 20, 05:35 PM posted to rec.aviation.soaring
Colin Roney
Default Magtape Xtra
Can anybody suggest a suitable solvent for removing the adhesive.
So far i`ve used Acetone and it`s only 50% successful.
Old May 23rd 20, 06:00 PM posted to rec.aviation.soaring
Jim N
3M Adhesive remover, it works like magic
Old May 23rd 20, 06:12 PM posted to rec.aviation.soaring
Pretty good luck with Goo Gone also.
Old May 23rd 20, 10:45 PM posted to rec.aviation.soaring
AS
I can second that! After the adhesive is dissolved, an oily residue is typically left, which I wash off with denatured alcohol.
Uli
'AS'
Old May 24th 20, 12:00 AM posted to rec.aviation.soaring
And the citrus smell is nicer, too. Then I celebrate with a fully natured alcohol.
Old May 24th 20, 01:57 AM posted to rec.aviation.soaring
Dave Nadler
Apparently Bob K is asleep. Sawzall!
Old May 24th 20, 01:01 PM posted to rec.aviation.soaring
George Underhill
Lighter fluid.
Old May 24th 20, 01:11 PM posted to rec.aviation.soaring
Dave Nadler
Try this: https://wingsandwheels.com/gj-cleaners.html
Old May 24th 20, 02:59 PM posted to rec.aviation.soaring
Waveguru
Auto gas works pretty well too.
Boggs
Old May 24th 20, 03:22 PM posted to rec.aviation.soaring
Hmmm, that's some serious tape. Might even work for taping the passenger outside as a Covid workaround.
https://www.lemark.co.uk/gaffer-tape...t-gaffer-tape/
3M makes a powerful adhesive remover, but the more useful the solvent, the more likely to eat the thing you use it on.
Definitely wax-be-gone and questionable for gelcoat friendly.
The GooGone MSDS says mostly Distillates (petroleum), hydrotreated light with a nice citrus scent.
For removing duct tape adhesive, more duct tape seems to work well.
Don't know if more gaffer's tape works for Gaffers tape?
