Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Primer/Sealer
Old April 10th 05, 06:04 PM
inxs02
Default Primer/Sealer
What type of primer/sealer is the best and easiest to apply before applying
the color coat on aircraft sheetmetal? Thanks for any info.
Old April 11th 05, 03:26 AM
mustanger
Zinc Chromate or Zinc Oxide has been the choice of aircraft manufacturers
since the 40's for priming or coating aluminum for corrosion protection.
Norm
aka Mustanger
www.aeromuseum.org
Old April 11th 05, 04:12 AM
ORVAL FAIRBAIRN
In article 2fl6e.25112$Vx1.1382@attbi_s01,
Norm
aka Mustanger
www.aeromuseum.org
Two-part epoxy primer over Alodine is the currently-preferred method --
especially when used with two-part polyurethane paints.
